Date/Time: Wed, 19 Feb 2025 00:23:03 +0000
charts keep pausing
View Count: 586
[2021-01-04 19:29:11]
User739935 - Posts: 37
In my message log I keep getting "Socket gracefully closed by remote side' Why is this happening?
[2021-01-04 19:39:53]
John - SC Support - Posts: 38036
If that is the only message, then that is normal. If you are getting other error messages, then we would need to see the entire Message Log.
[2021-01-05 02:57:54]
Consider using the Denali Exchange Data Feed:
If you are having trouble with your current data feed.
Date Time Of Last Edit: 2021-01-05 02:58:13
