Date/Time: Wed, 16 Sep 2026 01:18:04 +0000
Which service package and which exhange data feed should i have?
View Count: 2635
[2021-01-04 15:21:04]
stoneb26 - Posts: 1
Hello, new Sierra user here and i want to activate my product but i am very confused about which service package & data feeds i should have for my needs. I only need realtime data for US stocks (Nasdaq, NYSE & Amex) and nothing else. I also does not intend to trade via Sierra so i only need it for charting and i want to be able to use numberbars, market profile and DOM charts.
So which service package should i have for these purposes, standard or advanced?
And which realtime data feed should i select, i can only see the Denali exhange data feed as an option but this doesn`t have US stocks from what i can see?
Can you guide me to the right packages?
Best Regards,
Anders
[2021-01-04 17:47:38]
John - SC Support - Posts: 47903
First, you would need Package 5 in order to be able to use the Numbers Bars and the Market Profile. Refer to the information here on the differences between the packages:
Description of Service Packages and Pricing: Packages
Next, with regards to data for U.S. Equities, you need to use the Sierra Chart Exchange Data Feed for that particular exchange. Refer to the information here (note the Setup Instructions on that page):
Just one thing we want you to be aware of, the U.S. Equities data from the Sierra Chart Exchange Data Feed does not have Market Depth data. This will not impact the Numbers Bars or Market Depth, but we are not sure what you are looking for in terms of a DOM chart.
If you need Market Depth, then we would recommend using the IQFeed to get this data into Sierra Chart. Refer to the information here:
DTN IQ Feed Data Service
