Date/Time: Tue, 04 Mar 2025 09:26:03 +0000
[User Discussion] - Zig Zag mode 1 percentage bug and providing incorrect % values
View Count: 619
[2021-01-04 15:12:18]
User873130 - Posts: 47
When I use the zig zag indicator on mode 1 based on percentage, I am getting incorrect % numbers on the two Crypto instruments like ETHUSD-BMEX and XBT/USD. I tested this using the calculator set to % and it doesn't match the percentages in the zigzag mode 1. Any help is appreciated
[2021-12-07 17:46:35]
User75949 - Posts: 126
I have found the same problem, I have just made a post with some explanation
you can find it here
Zig Zag Cal MODE 1 - ISSUE
I'm waiting for an answer for a possible solution, if not the calculate mode 1 (%) is useless...
regards
