Date/Time: Sun, 04 Oct 2026 13:35:28 +0000
7 implementation queries?
View Count: 1354
| [2014-02-19 23:02:51] |
| User59863 - Posts: 36 |
1/ Possible to cusotmize time periods (x axis) eg 2 hrs, 4 hrs etc 2/ I am with IB & have paid the relevant subs But can't get symbols for: - e-mini Silver 1000 oz quote (SIL) - VIX futures (VIX) - COMEX Robusta Coffee 37500 lbs - Palladium 100 oz (PA) certain these are not the only symbols. 3/ Problem with many charts is the proportions always look so flat? (compare to charts on Finviz.com) Makes it hard to see well-defined channels, triangles etc 4/ Fix chart window tabs Left/Rigth scroll buttons One thing that irritates me is at bottom of bar with multiple chart window tabs there should be a right & left arrow scroll button on far left side. Only has it on far right side. So many times when instinctively look for button on far left side but it's not there Means when you are looking at the far left chart window (multiple charts open) & want to see the left chart next to it, you have to cursor across to the far right arrow buttons. How easy is it to have Scroll buttons also on right hand side where it is more logical...?? 5/ Is it possible to have bars showing only data from REGULAR trading hours only? Extended hours (outside regular hours) messes up bars 6/ Any audible alerts eg when price touches certain level or MACD crossover etc? 7/ What about alerts to mobile phone? Date Time Of Last Edit: 2014-02-19 23:08:45
| [2014-02-21 01:02:34] |
1. Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChangingTheChartBarsPeriod 2. You can manually specify symbols through File >> Find Symbol. Refer to: https://www.sierrachart.com/index.php?l=doc/IBSymbols.html We will add the ones you have listed that Sierra Chart does not currently have. 3. This is too vague for us to help with. Post an image of the chart by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image 4. Eventually this will be added. 5. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html 6. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html 7. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
