Date/Time: Thu, 13 Feb 2025 22:51:03 +0000
Question about switch from CQG to Denali
View Count: 751
[2021-01-03 19:03:46] |
User475690 - Posts: 34 |
1. Is it correct that if I switch to Denali then I can get more tick data? I have the question because according to Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245603 above link mention that "If your Sierra Chart account is through AMP, you will need to be on the Advanced Service Package 5 to have access to Sierra Chart historical data" So does this imply that just because I still use AMP free package of sierra chart, even I switch from CQG to Denali then I still can't have 10 years tick of tick data of CME bundle exchanges? 2. I knew CME bundle top of book data price is 3.25 , I want to know whether will be charged $5.00 admin fee base on https://support.ampglobal.com/hc/en-us/articles/360045232634-CME-Monthly-Data-Fee-Increase-Effective-April-1-2020 (TT charging $2.00 admin fee (per Exchange) or $5.00 admin fee (Bundle) + CME FEE), if switch from CQG to Denali? 3. if I switch from CQG to Denali, will symbol I am trading need to change ? |
[2021-01-03 20:10:39] |
. Is it correct that if I switch to Denali then I can get more tick data? Yes.So does this imply that just because I still use AMP free package of sierra chart, even I switch from CQG to Denali No it does not imply that.then I still can't have 10 years tick of tick data of CME bundle exchanges? 2. Those fees do not apply but we recommend you pay for the Denali Data Feed directly so you are in complete control and you do not put your reliance on someone else. Instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* 3. Yes if you change to the Sierra Chart Order Routing Service which we recommend. Full documentation is here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions There is a command to automatically translate symbols and that is explained in the instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-03 20:11:41
[2021-01-04 00:01:23] |
Then how to pay for the Denali Data Feed directly ?
[2021-01-04 00:07:17] |
You just simply add funds to your Sierra Chart account: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit And then you follow the step-by-step instructions here to activate the data feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* In this way you do not involve the broker at all. You can activate it and deactivate it as you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
