Date/Time: Thu, 13 Feb 2025 22:52:17 +0000
Replay Chart
View Count: 541
[2021-01-03 18:54:32] |
User737360 - Posts: 23 |
Hi, I have a problem with the replay chart. I made some trades on November 4th, 2019 and would like to look at them again. However, the price and time are no longer the same. How can I set this correctly? Best regards |
[2021-01-04 03:53:34] |
Make sure this setting is not set to one of the back adjusted options: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-04 03:53:44
