Date/Time: Fri, 18 Sep 2026 21:47:15 +0000
Compiled studies with SC compiler not accepted after migration to newer version
View Count: 779
| [2021-01-02 19:11:22] |
| User470516 - Posts: 78 |
Dear SC Team, I was using version 2146. I updated to the latest version (2214). I was asked to recompile all studies in my chartbooks which I did. Studies have been recompiled using SC compiler with no compiling error. The .dlls appear properly in the "Data" folder. The problem is there are error messages in the message Log that say the studies need to be recompiled and they do not display in the Chart Studies Box, although they have been recompiled. If the studies are recompiled using MS Visual Studio, there are no such messages and the studies function again. We have 3 different platforms and the problem is the same on all of them. Could you please check and let me know? Thanks! Regards |
| [2021-01-03 20:16:09] |
This does not make sense. We encountered no such problem. Tell us exactly how you are doing this: Studies have been recompiled using SC compiler with no compiling error.
Maybe you are looking at older DLL files which have not been recompiled which are giving this message: The problem is there are error messages in the message Log that say the studies need to be recompiled and they do not display in the Chart Studies Box, If this is the case, then delete those from the Data folder.
