Date/Time: Sun, 13 Sep 2026 03:08:47 +0000
Issue with opening of multiple instances
View Count: 1330
| [2021-01-02 18:39:59] |
| User472757 - Posts: 5 |
I'm having trouble getting my instances to open up correctly. I have 3 instances and every time I open up Sierra only the 1st and 3rd instance opens. I added a 4th instance and now when I open Sierra only the 1st and 4th instance opens. After everything opens I can open the other instances w/no problem. The only other change I've made is upgraded to Package 5 for TPO charting. I've tried for hours trying various fixes and searching for a solution but have come up short. I can attach a Message Log if that helps. Thx for a great program! |
| [2021-01-04 03:08:20] |
What exactly is this setting set to?: General Settings Window: Instances to Run on Startup (Global Settings >> General Settings >> General >> New Instances) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-04 03:55:49] |
Oh my...after hours of searching I completely missed the "," needed for additional instances. Thank you for the help! You've got a great program.... |
