Date/Time: Mon, 25 Nov 2024 16:43:24 +0000
Bar time count down
View Count: 2898
[2014-02-19 21:25:14]
User87794 - Posts: 10
Hi
1)Is there the ability to have a end of bar/candle count down. In other words a timer that counts down to the end of the bar/candle?
2)Can I operate my charts on GMT time when I am physically not in that time zone?
3)Can I set up reoccurring vertical lines that pop up as the chart tracks across in time? I want to use them to acknowledge different time zones. (it am trading currency)
4) can I get the bid and ask line to run right across the page?
5)Can I link like charts(same currency on a different time zone) in such a way that when I draw a line or rectangle it will appear on the other charts?
6) When/after drawing a rectangle I want to change its location by using exact numbers. So when I go to Rectangle properties and attemp to move the anchors - they are locked - how do I change the date and time??
thank you for your assistance
R
[2014-02-20 21:05:35]
1. See:
http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#BarCountdownTimer
2. Yes. See:
http://www.sierrachart.com/index.php?l=doc/doc_TimeZone.html
3. Yes. Use the Time Line study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s181
Instructions to use a study:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart
4. Have a look at the Time and Sales studies:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s120
5. See:
http://www.sierrachart.com/index.php?l=doc/helpdetails72.html
6. This is supported in the current version of Sierra Chart. Update following the instructions here:
http://www.sierrachart.com/index.php?l=doc/download.php#FastUpdate
