Date/Time: Thu, 13 Feb 2025 23:33:05 +0000
SC Data - All Services: No Intraday Forex Data After 2:01 PM on Dec. 31st
View Count: 597
[2021-01-02 10:40:35] |
Lesmond - Posts: 22 |
FX data is missing after 14:01 EST on Dec. 31st . I have tried the following symbols: EURUSD USDJPY USDCAD AUDUSD NZDUSD USDCHF GBPUSD CADJPY AUDJPY NZDJPY Futures and Market Stats are ok: TICK-NYSE YMH21-CBOT ESH21-CME NQH21-CME CLG21-NYMEX Interactive Brokers has FX data available until 15:59. |
[2021-01-02 20:09:32] |
User99582 - Posts: 8 |
I'd like to add that I have no historical data downloaded since Dec 31st either. Using the instructions -- Downloading Historical Daily Data Doesn't yield any results. I checked the message log, no errors found. I'm running version 2215 (64-Bit) on Windows 10. |
[2021-01-02 23:52:55] |
In regards to post #1 those Forex symbols are from FXCM and they did not provide data after that date and time. In regards to post #2, tell us what specific symbol you are referring to. Just one symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-02 23:53:19
[2021-01-03 00:27:35] |
Sorry for not specifying earlier -- BTC-BSTMP Last bar I show on the Daily chart is 12/30/20 Thank you |
[2021-01-03 12:12:11] |
We have discontinued Bitstamp data. We have several other sources of crypto currency data: Binance Bitfinex BitMex Deribit For more information, refer to: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
