Date/Time: Mon, 25 Nov 2024 18:34:28 +0000
Quote Boards
View Count: 1555
[2014-02-19 20:48:07] |
User39772 - Posts: 311 |
Is it possible to define Alerts within the Quote board based on formulas, like in the spread sheets e.g., so that - if a condition triggers - a column for the alert in the quote board e.g. changes color (or the symbol that meets the alert conditions itself). |
[2014-02-19 21:34:28] |
Not at this time.
[2014-02-21 13:22:07] |
Would it be possible to implement at least some filters for the fields available, e.g. Volume, Price, NetChange etc. soon ?
[2014-03-05 12:15:40] |
User23386 - Posts: 43 |
When do you think sierra will make available the option to customise the quote board coloring options and add formulas for the various fields currently available? It would make a nice addition to the sierra platform to be able to customise the coloring and formula for NetChange%, Change from Open, Percent From Low etc. I have attached 2 screen caps for potential set ups. I already have the formulas for these coloring options if sierra wants them. You could color code the Net Change % based upon actual % change, the higher the % change the darker the coloring, the lower the % change the lighter the coloring. When any symbols gets to within say 10% of it high/low the background color and foreground color would change and when any symbols breaks to new highs or new lows you could have the text plotting NEW HIGH, NEW LOW.
Quote Window New Features Percentages Colors.png / V - Attached On 2014-03-05 12:06:44 UTC - Size: 21.83 KB - 450 views Quote Window New Features.png / V - Attached On 2014-03-05 12:07:21 UTC - Size: 13.32 KB - 457 views |
