Date/Time: Mon, 17 Mar 2025 11:32:04 +0000
v2207 Shortcuts not working for TPO Profile Chart Commands >> Merge Profile Begin & En
View Count: 752
[2021-01-01 19:53:20]
User247273 - Posts: 37
I'm running version 2207
In the "Customize Keyboard Shortcuts" window, the following items are visible in the Commands list, but the "Selected Command" field remains blank if you select either one.
- TPO Profile Chart Commands >> Merge Profile Begin
- TPO Profile Chart Commands >> Merge Profile End
When I try to assign a shortcut, the "Key Currently Used By" field remains blank and does not update to the assigned shortcut. I tested to see if the shortcuts I assigned for either command might work anyway, but they did not.
[2021-04-08 16:16:47]
Just following up to say this problem is still present in version 2245.
[2021-04-08 18:19:27]
John - SC Support - Posts: 38678
We do see it. We'll try to get it corrected soon.
[2022-09-09 14:54:59]
Just following up to say I'm still having the same problem in the current version (2425).
[2022-09-10 06:20:39]
Sierra_Chart Engineering - Posts: 18805
Not sure why this had gotten overlooked for such a long time. We are looking into it now.
[2022-09-10 06:52:30]
This will be resolved in the next release.
