Date/Time: Thu, 13 Feb 2025 23:07:56 +0000
Multiple Instances of SC - simultaneous execution
View Count: 546
[2021-01-01 18:08:08]
User594974 - Posts: 35
Hello, and happy 2021.
I've researched and can't find a definitive answer to this...
I have two different brokers (AMP & Ironbeam) both utilizing CQG and using different instances of Sierra. I'd really like to be able to execute on one instance (AMP) and have it automatically execute the same orders on instance 2 (Ironbeam).
Is this possible?
Thank you.
Cheers!
[2021-01-02 03:14:02]
The only way this is possible is to use this feature which works with the Sierra Chart Order Routing Service:
Order Allocation to Trade Accounts
So you cannot use CQG with this. Although Iron Beam does not support the Sierra Chart order routing service.
Date Time Of Last Edit: 2021-01-02 08:05:32
