Date/Time: Thu, 13 Feb 2025 23:16:46 +0000
setup "SC Futures Order Routing Service With Data" on V.2207 and my study has disappea
View Count: 465
[2020-12-30 19:39:28] |
GlasperlenSpieler - Posts: 21 |
Dear all, I did all the steps required to setup "Sierra Chart Futures Order Routing Service With Data" including update to version 2207. It looks like the new setup works, except my most important study disappeared from all Charts :( When I open it in Chart Studies it says: "Study Settings: The advanced study C:\SierraChart\.topdll.dll needs to be recompiled to be used on this version 2207" A) What does it mean? And what do I have to do now to get it back? B) Why did it disappear? Thank you in advance for your help! |
[2020-12-30 20:15:33] |
You do need to recompile the custom study source code for that version and higher. Do you have the source code? Or where did you get the custom study from? Relevant documentation: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-03 19:55:25] |
Thank you for your quick and helpful response ! I got great help in the meantime, the custom study is recompiled and looks awesome again :) |
