Date/Time: Mon, 25 Nov 2024 14:48:07 +0000
Export graphic settings for reuse in another account?
View Count: 1650
[2014-02-19 16:27:16]
scotpip - Posts: 2
Hi
I've set up a number of global graphic settings, and now I'd like to share them with another Sierra user.
There doesn't seem to be any obvious way to export and import these settings.
I tried sharing Sierra3.cfg but that didn't work.
Is there any way this can be done, or do you have to set up the global settings manually for each account?
[2014-02-19 17:18:42]
The Global Graphics Settings are contained in the Sierra3.cfg file.
When copying this file from one Sierra Chart installation to the other, Sierra Chart must not be running when taking a copy of it and when saving it into the new folder. This must be the source of the problem.
The other thing to check is to make sure the chart is not set to use the chart specific Graphics Settings. This is set through Chart >> Graphics Settings.
Date Time Of Last Edit: 2014-02-19 17:40:22
[2014-02-19 17:33:42]
scotpip - Posts: 2
Thanks for the quick response - will give this a try!
