Date/Time: Tue, 30 Jun 2026 00:58:14 +0000
MBO Data in Denali
View Count: 2615
[2020-12-29 22:42:11]
John Mc - Posts: 32
I have upgraded SC to version 2207 (64 bit)
I have gone through the setup process for showing MBO data from Denali (which I have setup and working) but do not see an option "Subscribe Market by Order Data When Market Depth Subscribed' under the Global Settings>>Sierra Chart Server Settings windows.
I am assuming this prevents me from seeing The Bid Market Orders Column, Ask Market Order Column, or the Combined Bid Ask Market Orders Column.
What do I need to do to get these options to appear?
Thanx - John
Reading Internal Order ID file. | 2020-12-29 15:51:37.701
Reading Trade Orders file. | 2020-12-29 15:51:37.819
Reading Trade Positions file. | 2020-12-29 15:51:37.819
Reading Account Balance file. | 2020-12-29 15:51:37.819
UDPListener (1640). Port 22904 | Listening on UDP port 22904. | 2020-12-29 15:51:37.840
Software version: 2207 64-bit | 2020-12-29 15:51:37.840
Primary Thread ID: 8232 | 2020-12-29 15:51:37.840
Usage end date: 2021-07-09 | 2020-12-29 15:51:37.840
Enabled for: Advanced Features 2. | 2020-12-29 15:51:37.840
Enabled for: Sierra Chart Historical Data Service. | 2020-12-29 15:51:37.840
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-12-29 15:51:37.840
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-12-29 15:51:37.840
Enabled for exchange2: CME (Trading Account Required) | 2020-12-29 15:51:37.840
Enabled for exchange2: CBOT (Trading Account Required) | 2020-12-29 15:51:37.840
Enabled for exchange2: COMEX (Trading Account Required) | 2020-12-29 15:51:37.840
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-12-29 15:51:37.840
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-12-29 15:51:37.840
Current selected Data/Trading service: SC Data - All Services | 2020-12-29 15:51:37.840
Custom symbol settings values: enabled | 2020-12-29 15:51:37.840
Chart Update Interval: 500 | 2020-12-29 15:51:37.840
Intraday Data Storage Time Unit: 0 | 2020-12-29 15:51:37.840
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-12-29 15:51:37.840
2020-12-29 21:51:37 Local computer time in UTC | 2020-12-29 15:51:37.841
2020-12-29 15:51:37 Local computer time in SC Time Zone | 2020-12-29 15:51:37.841
2020-12-29 21:51:37 Server time in UTC | 2020-12-29 15:51:37.841
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-12-29 15:51:37.841
Program path: C:\SierraChart\ | 2020-12-29 15:51:37.841
Data Files path: C:\SierraChart\Data\ | 2020-12-29 15:51:37.841
OS Version Number: 10.0 | 2020-12-29 15:51:37.841
Locale Setting: C | 2020-12-29 15:51:37.841
DLLs: ETG Audio.dll, ETOFSv3_64.dll, openal32.dll, sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll, VerbalJournal.dll, VerbalJournal_2151.dll, VerbalJournal_2151_64.dll, VerbalJournal_64.dll | 2020-12-29 15:51:37.841
Allowed protected custom studies: ETG Audio, SST_FreeBundle, VerbalJournal | 2020-12-29 15:51:37.841
Date Time Of Last Edit: 2020-12-31 19:13:29
[2020-12-29 23:19:56]
Update to the prerelease with Help >> Download Prerelease.
[2020-12-30 14:29:30]
John Mc - Posts: 32
I upgraded to the current version (and I verified) it worked. When I go to the customize screen I still do not see any MBO items under the Hidden Items.
Any other suggestions?
Thanx - John
[2020-12-30 14:38:38]
John - SC Support - Posts: 46952
We assume you mean the "Customize Trade/Chart DOM Columns" screen. You want to select the items on the left named the following:
- Bid Market Orders Column
- Ask Market Orders Column
- Combined Bid/Ask Market Orders Column
Then use the -> button to add the columns to the right. You will find the instructions for this at Step #4 of the instructions here:
Market By Order Data: Step-by-Step Instructions
[2020-12-30 16:42:32]
John Mc - Posts: 32
I added those columns to my screen but nothing appears in them. I understand thoat it filters for a certain size. I do not even see orders come through given any size. I am watching for size on a different software package so I can tell when orders come through. Also, no sure if it should be showing but when I add the MBO columns nothing appears for a column title.
Let me know if I need to do anything.
Thanx - John
[2020-12-30 17:12:29]
What symbol are you doing this on? The ES doesn't tend to have many large orders, in fact, we just took a look and do not see any MBO data larger than 10, so nothing is showing up for that symbol.
Try a different symbol like 6B, which does have a lot of larger orders.
As you stated, it will only show orders greater than 10 by default.
There will not be a column title unless you add it (this is true for all columns). Refer to the information here:
Global Trade Settings Windows: Custom Title (Trade >> Customize Chart/Trade DOM Columns)
[2020-12-31 19:12:26]
There are definitely plenty of orders on ES above 10, at least at this time. Here is what we see currently:
http://www.sierrachart.com/image.php?Image=1609441926612.png
[2021-01-04 16:44:44]
John Mc - Posts: 32
I checked today and I do not see anything in the MBO columns I added to my DOM. I restarted Sierra today so it would have the most current data.
What should I try next?
[2021-01-04 18:34:43]
Please go through these Instructions and see if anything is not set correctly:
Let us know if you are still having an issue after doing this.
Also, the ES is showing a lot of large trades right now in the MBO data, so you should be able to see the information for that symbol.
[2021-01-05 12:43:30]
John Mc - Posts: 32
That did it. Thanx for the help.
You can close this support request.
