Date/Time: Thu, 13 Feb 2025 22:02:00 +0000
Trade chart per tick also bars
View Count: 463
[2020-12-29 20:16:27] |
User957123 - Posts: 4 |
Hi, as the title suggests, I would like to know why in the tick chart there are bars that therefore make multiple prices mark at the same time (which is not possible). Before I was with transact and this did not happen, now I have paid sierra for a month because Amp still has to create my account and I need to try some studies but if the tick chart is like this it doesn't work for me .. Thanks in advance. |
[2020-12-29 20:33:18] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
