Date/Time: Mon, 25 Nov 2024 14:43:25 +0000
Custom tab label w/ time period
View Count: 1017
[2014-02-19 16:00:01] |
cazeek - Posts: 33 |
Hello, This is getting a little spoiled, but is there any shot you can add an option to display the time period on tabs with custom labels. It would be similar to the way the tabs will say "Daily", "Weekly", etc following the name if the name is unaltered, but it would simply follow the custom tab name. Thanks as always. You guys do great work. Steven |
