Date/Time: Thu, 13 Feb 2025 23:14:50 +0000
bonds 29/12
View Count: 616
[2020-12-29 15:15:27] |
User518511 - Posts: 8 |
I only placed one order to buy bonds got out in a profit... but the dom tells me I,m 9/32p in the red so loss....please explain..
[2020-12-29 19:16:25] |
We see you are using CQG. The first thing you need to do is update to the current version. Instructions: Software Download: Fast Update Most likely you are referring to the Daily Profit/Loss. Refer to the documentation here: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-29 19:17:22
[2020-12-31 03:16:52] |
it wouldnt update, I sent the log to support david |
[2020-12-31 15:02:59] |
John - SC Support - Posts: 37947 |
Refer to the information here, given what is in your log: Software Download: Resolving 'Access is Denied' Errors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-31 18:16:55] |
Also try the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
