Date/Time: Thu, 13 Feb 2025 22:15:14 +0000
BMF Weekly Data problem
View Count: 501
[2020-12-28 21:16:58] |
User613135 - Posts: 5 |
I have historical charts for 2 BMF markets that have not updated since 12-18-20 (WING21 and XDF21). I have tried creating new charts, reload/recalc, and delete/download but none worked. Attached is the error message. Daily and monthly charts are fine. Could you please advise? Thanks
Private File |
[2020-12-29 01:28:31] |
There are restrictions on this data from our data provider but you should have access to it because you are using the Sierra Chart Exchange Data Feed. They are working on making it available for those users. We hope this will be in the next two or three days. You also need to translate the symbols in your Chartbook to the current format by using this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-29 01:30:20
