Date/Time: Thu, 13 Feb 2025 21:49:17 +0000
Do you need a subscription to use the simulation?
View Count: 513
[2020-12-28 19:59:34] |
User582874 - Posts: 2 |
Hello Do I need a subscription to use the simulation? I only need historical data to practice on. Regards, Lee |
[2020-12-28 22:14:19] |
John - SC Support - Posts: 37944 |
It is not necessary to have an active service with Sierra Chart in order to continue to use the software. Refer to the information here: Sierra Chart Purchase and License Information: Free Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-28 22:38:46] |
You do need an active Sierra Chart account to access historical data. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-28 22:38:53
