Date/Time: Fri, 07 Feb 2025 14:54:43 +0000
[Programming Help] - Source code for
View Count: 1597
[2020-12-28 18:36:59]
User112118 - Posts: 8
Are we able to view the source code for "Color Bar Based on Alert Condition" or "Color Background Based on Alert Condition"? If so, where can we find it?
[2020-12-28 19:14:19]
John - SC Support - Posts: 37808
The source code for those studies is not available. Refer to the information here as to why:
How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available
[2020-12-30 07:26:26]
User90125 - Posts: 715
Find this study and edit it as needed:
Trading System Based on Alert Condition
Look for: SierraChartStudies_64.scsf_TradingSystemBasedOnAlertCondition
Be sure to remove all the Trading-related code and update it with whatever will trigger a Color Bar or change the Background Color for you.
[2020-12-30 07:39:31]
#include "sierrachart.h"
SCSFExport scsf_TradingSystemBasedOnAlertCondition(SCStudyInterfaceRef sc)
  SCInputRef Input_Enabled = sc.Input[0];
  SCInputRef Input_NumBarsToCalculate = sc.Input[1];
  SCInputRef Input_DrawStyleOffsetType = sc.Input[2];
  SCInputRef Input_PercentageOrTicksOffset = sc.Input[3];
  SCInputRef Input_OrderActionOnAlert = sc.Input[4];
  SCInputRef Input_EvaluateOnBarCloseOnly = sc.Input[5];
  SCInputRef Input_SendTradeOrdersToTradeService = sc.Input[6];
  SCInputRef Input_MaximumPositionAllowed = sc.Input[7];
  SCInputRef Input_MaximumLongTradesPerDay = sc.Input[8];
  SCInputRef Input_MaximumShortTradesPerDay = sc.Input[9];
  SCInputRef Input_EnableDebuggingOutput = sc.Input[10];
  SCInputRef Input_CancelAllWorkingOrdersOnExit = sc.Input[11];
  SCInputRef Input_AllowTradingOnlyDuringTimeRange = sc.Input[12];
  SCInputRef Input_StartTimeForAllowedTimeRange = sc.Input[13];
  SCInputRef Input_EndTimeForAllowedTimeRange = sc.Input[14];
  SCInputRef Input_AllowOnlyOneTradePerBar = sc.Input[15];
  SCInputRef Input_Version = sc.Input[16];
  SCInputRef Input_SupportReversals = sc.Input[17];
  SCInputRef Input_AllowMultipleEntriesInSameDirection = sc.Input[18];
  SCInputRef Input_AllowEntryWithWorkingOrders = sc.Input[19];
  SCInputRef Input_ControlBarButtonNumberForEnableDisable = sc.Input[20];
  SCSubgraphRef Subgraph_BuyEntry = sc.Subgraph[0];
  SCSubgraphRef Subgraph_SellEntry = sc.Subgraph[1];
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Trading System Based on Alert Condition";
    sc.StudyDescription = "";
    sc.AutoLoop = 0; // manual looping
    sc.GraphRegion = 0;
    sc.CalculationPrecedence = LOW_PREC_LEVEL;
    Input_Enabled.Name = "Enabled";
    Input_Enabled.SetYesNo(false);
    Input_NumBarsToCalculate.Name = "Number of Bars to Calculate";
    Input_NumBarsToCalculate.SetInt(2000);
    Input_NumBarsToCalculate.SetIntLimits(1, MAX_STUDY_LENGTH);
    //Input_DrawStyleOffsetType.Name = "Draw Style Offset Type";
    //Input_DrawStyleOffsetType.SetCustomInputStrings("Percentage;Number of Ticks");
    //Input_PercentageOrTicksOffset.Name = "Percentage or Ticks Offset";
    //Input_PercentageOrTicksOffset.SetFloat(0);
    Input_OrderActionOnAlert.Name = "Order Action on Alert";
    Input_OrderActionOnAlert.SetCustomInputStrings("Buy Entry;Buy Exit;Sell Entry;Sell Exit");
    Input_OrderActionOnAlert.SetCustomInputIndex(0);
    Input_EvaluateOnBarCloseOnly.Name = "Evaluate on Bar Close Only";
    Input_EvaluateOnBarCloseOnly.SetYesNo(true);
    Input_SendTradeOrdersToTradeService.Name = "Send Trade Orders to Trade Service";
    Input_SendTradeOrdersToTradeService.SetYesNo(false);
    Input_MaximumPositionAllowed.Name = "Maximum Position Allowed";
    Input_MaximumPositionAllowed.SetInt(1);
    Input_MaximumLongTradesPerDay.Name = "Maximum Long Trades Per Day";
    Input_MaximumLongTradesPerDay.SetInt(2);
    Input_MaximumShortTradesPerDay.Name = "Maximum Short Trades Per Day";
    Input_MaximumShortTradesPerDay.SetInt(2);
    Input_CancelAllWorkingOrdersOnExit.Name = "Cancel All Working Orders On Exit";
    Input_CancelAllWorkingOrdersOnExit.SetYesNo(false);
    Input_EnableDebuggingOutput.Name = "Enable Debugging Output";
    Input_EnableDebuggingOutput.SetYesNo(false);
    Input_AllowTradingOnlyDuringTimeRange.Name = "Allow Trading Only During Time Range";
    Input_AllowTradingOnlyDuringTimeRange.SetYesNo(false);
    Input_StartTimeForAllowedTimeRange.Name = "Start Time For Allowed Time Range";
    Input_StartTimeForAllowedTimeRange.SetTime(HMS_TIME(0, 0, 0));
    Input_EndTimeForAllowedTimeRange.Name = "End Time For Allowed Time Range";
    Input_EndTimeForAllowedTimeRange.SetTime(HMS_TIME(23, 59, 59));
    Input_AllowOnlyOneTradePerBar.Name = "Allow Only One Trade per Bar";
    Input_AllowOnlyOneTradePerBar.SetYesNo(true);
    Input_SupportReversals.Name = "Support Reversals";
    Input_SupportReversals.SetYesNo(false);
    Input_AllowMultipleEntriesInSameDirection.Name = "Allow Multiple Entries In Same Direction";
    Input_AllowMultipleEntriesInSameDirection.SetYesNo(false);
    Input_AllowEntryWithWorkingOrders.Name = "Allow Entry With Working Orders";
    Input_AllowEntryWithWorkingOrders.SetYesNo(false);
    Input_ControlBarButtonNumberForEnableDisable.Name = "ACS Control Bar Button # for Enable/Disable";
    Input_ControlBarButtonNumberForEnableDisable.SetInt(1);
    Input_ControlBarButtonNumberForEnableDisable.SetIntLimits(1, MAX_ACS_BUTTONS);
    Input_Version.SetInt(2);
    Subgraph_BuyEntry.Name = "Buy";
    Subgraph_BuyEntry.DrawStyle = DRAWSTYLE_POINT_ON_HIGH;
    Subgraph_BuyEntry.LineWidth = 5;
    Subgraph_SellEntry.Name = "Sell";
    Subgraph_SellEntry.DrawStyle = DRAWSTYLE_POINT_ON_LOW;
    Subgraph_SellEntry.LineWidth = 5;
    sc.AllowMultipleEntriesInSameDirection = false;
    sc.SupportReversals = false;
    sc.AllowOppositeEntryWithOpposingPositionOrOrders = false;
    sc.SupportAttachedOrdersForTrading = false;
    sc.UseGUIAttachedOrderSetting = true;
    sc.CancelAllOrdersOnEntriesAndReversals = false;
    sc.AllowEntryWithWorkingOrders = false;
    // Only 1 trade for each Order Action type is allowed per bar.
    sc.AllowOnlyOneTradePerBar = true;
    //This should be set to true when a trading study uses trading functions.
    sc.MaintainTradeStatisticsAndTradesData = true;
    return;
  if (Input_Version.GetInt() < 2)
  sc.AllowOnlyOneTradePerBar = Input_AllowOnlyOneTradePerBar.GetYesNo();
  sc.MaximumPositionAllowed = Input_MaximumPositionAllowed.GetInt();
  sc.SendOrdersToTradeService = Input_SendTradeOrdersToTradeService.GetYesNo();
  sc.CancelAllWorkingOrdersOnExit = Input_CancelAllWorkingOrdersOnExit.GetYesNo();
  sc.SupportReversals = Input_SupportReversals.GetYesNo();
  sc.AllowMultipleEntriesInSameDirection = Input_AllowMultipleEntriesInSameDirection.GetYesNo();
  sc.AllowEntryWithWorkingOrders = Input_AllowEntryWithWorkingOrders.GetYesNo();
  if (sc.MenuEventID == Input_ControlBarButtonNumberForEnableDisable.GetInt())
    const int ButtonState = (sc.PointerEventType == SC_ACS_BUTTON_ON) ? 1 : 0;
    Input_Enabled.SetYesNo(ButtonState);
  if (!Input_Enabled.GetYesNo() || sc.LastCallToFunction)
    return;
  int& r_LastDebugMessageType = sc.GetPersistentInt(1);
  int& r_PriorFormulaState = sc.GetPersistentInt(2);
  if (sc.IsFullRecalculation)
    r_LastDebugMessageType = 0;
    r_PriorFormulaState = 0;
    // set ACS Tool Control Bar tool tip
    sc.SetCustomStudyControlBarButtonHoverText(Input_ControlBarButtonNumberForEnableDisable.GetInt(), "Enable/Disable Trade System Based on Alert Condition");
    sc.SetCustomStudyControlBarButtonEnable(Input_ControlBarButtonNumberForEnableDisable.GetInt(), Input_Enabled.GetBoolean());
  // Figure out the last bar to evaluate
  int LastIndex = sc.ArraySize - 1;
  if (Input_EvaluateOnBarCloseOnly.GetYesNo())
    --LastIndex;
  const int EarliestIndexToCalculate = LastIndex - Input_NumBarsToCalculate.GetInt() + 1;
  int CalculationStartIndex = sc.UpdateStartIndex;// sc.GetCalculationStartIndexForStudy();
  if (CalculationStartIndex < EarliestIndexToCalculate)
    CalculationStartIndex = EarliestIndexToCalculate;
  sc.EarliestUpdateSubgraphDataArrayIndex = CalculationStartIndex;
  s_SCPositionData PositionData;
  s_ACSTradeStatistics TradeStatistics;
  SCString TradeNotAllowedReason;
  const bool IsDownloadingHistoricalData = sc.ChartIsDownloadingHistoricalData(sc.ChartNumber) != 0;
  bool IsTradeAllowed = !sc.IsFullRecalculation && !IsDownloadingHistoricalData;
  if (Input_EnableDebuggingOutput.GetYesNo())
      TradeNotAllowedReason = "Is full recalculation";
    else if (IsDownloadingHistoricalData)
      TradeNotAllowedReason = "Downloading historical data";
  if (Input_AllowTradingOnlyDuringTimeRange.GetYesNo())
    const SCDateTime LastBarDateTime = sc.LatestDateTimeForLastBar;
    const int LastBarTimeInSeconds = LastBarDateTime.GetTimeInSeconds();
    bool LastIndexIsInAllowedTimeRange = false;
    if (Input_StartTimeForAllowedTimeRange.GetTime() <= Input_EndTimeForAllowedTimeRange.GetTime())
      LastIndexIsInAllowedTimeRange = (LastBarTimeInSeconds >= Input_StartTimeForAllowedTimeRange.GetTime()
        && LastBarTimeInSeconds <= Input_EndTimeForAllowedTimeRange.GetTime()
    else //Reversed times.
        || LastBarTimeInSeconds <= Input_EndTimeForAllowedTimeRange.GetTime()
    if (!LastIndexIsInAllowedTimeRange)
      IsTradeAllowed = false;
      TradeNotAllowedReason = "Not within allowed time range";
  bool ParseAndSetFormula = sc.IsFullRecalculation;
  // Evaluate each of the bars
  for (int BarIndex = CalculationStartIndex; BarIndex <= LastIndex; ++BarIndex)
    int FormulaResult = sc.EvaluateAlertConditionFormulaAsBoolean(BarIndex, ParseAndSetFormula);
    ParseAndSetFormula = false;
    bool StateHasChanged = true;
    if (FormulaResult == r_PriorFormulaState )
      TradeNotAllowedReason = "Formula state has not changed";
      StateHasChanged = false;
    r_PriorFormulaState = FormulaResult;
    // Determine the result
    if (FormulaResult != 0) //Formula is true
      if (IsTradeAllowed)
        sc.GetTradePosition(PositionData);
        sc.GetTradeStatisticsForSymbol(0, 1, TradeStatistics);
      if (Input_OrderActionOnAlert.GetIndex() == 0)// Buy entry
        Subgraph_BuyEntry[BarIndex] = 1;
        Subgraph_SellEntry[BarIndex] = 0;
        if (IsTradeAllowed && StateHasChanged)
          if (PositionData.PositionQuantityWithAllWorkingOrders == 0
            || Input_AllowMultipleEntriesInSameDirection.GetYesNo()
            || Input_SupportReversals.GetYesNo())
            if (TradeStatistics.TotalLongTrades < Input_MaximumLongTradesPerDay.GetInt())
              s_SCNewOrder NewOrder;
              NewOrder.OrderQuantity = sc.TradeWindowOrderQuantity;
              NewOrder.OrderType = SCT_ORDERTYPE_MARKET;
              int Result = (int)sc.BuyEntry(NewOrder, BarIndex);
              if (Result < 0)
                sc.AddMessageToTradeServiceLog(sc.GetTradingErrorTextMessage(Result), false, true);
            else if (Input_EnableDebuggingOutput.GetYesNo())
              sc.AddMessageToTradeServiceLog("Buy Entry signal ignored. Maximum Long Trades reached.", false, true);
            sc.AddMessageToTradeServiceLog("Buy Entry signal ignored. Position exists.", false, true);
        else if (Input_EnableDebuggingOutput.GetYesNo() && r_LastDebugMessageType != 1)
          SCString MessageText("Trading is not allowed. Reason: ");
          MessageText += TradeNotAllowedReason;
          sc.AddMessageToTradeServiceLog(MessageText, 0);
          r_LastDebugMessageType = 1;
      else if (Input_OrderActionOnAlert.GetIndex() == 1)// Buy exit
        Subgraph_BuyEntry[BarIndex] = 0;
        Subgraph_SellEntry[BarIndex] = 1;
          if (PositionData.PositionQuantity > 0)
            int Result = (int)sc.BuyExit(NewOrder, BarIndex);
            if (Result < 0)
            sc.AddMessageToTradeServiceLog("Buy Exit signal ignored. Long position does not exist.", false, true);
          else
      else if(Input_OrderActionOnAlert.GetIndex() == 2)// Sell entry
            if (TradeStatistics.TotalShortTrades < Input_MaximumShortTradesPerDay.GetInt())
              int Result = (int)sc.SellEntry(NewOrder, BarIndex);
              if (Result < 0)
              sc.AddMessageToTradeServiceLog("Sell Entry signal ignored. Maximum Short Trades reached.", false, true);
            sc.AddMessageToTradeServiceLog("Sell Entry signal ignored. Position exists.", false, true);
      else if (Input_OrderActionOnAlert.GetIndex() == 3)// Sell exit
          if (PositionData.PositionQuantity < 0)
            int Result = (int)sc.SellExit(NewOrder, BarIndex);
            if (Result < 0)
            sc.AddMessageToTradeServiceLog("Sell Exit signal ignored. Short position does not exist.", false, true);
          else
    else
    // Reset the prior formula state to 0 if we did not allow trading in order to not prevent trading the next time it is allowed if the state did not change.
    if (!IsTradeAllowed)
attachmentTradingSystemBasedOnAlertCondition[1].cpp - Attached On 2020-12-30 07:36:21 UTC - Size: 14.92 KB - 400 views
[2020-12-30 07:47:21]
Have a look at this ACSIL function:
sc.EvaluateGivenAlertConditionFormulaAsDouble()
Date Time Of Last Edit: 2020-12-30 07:47:33
[2021-08-11 15:33:43]
jmt816 - Posts: 45
MAX_ACS_BUTTONS no longer a valid constant? I am using v2281, haven't coded in a few months, now that const is undefined?
[2021-08-13 17:31:41]
No that is old.
const int MAX_ACS_CONTROL_BAR_BUTTONS = 150;
