Date/Time: Thu, 13 Feb 2025 22:11:48 +0000
Need help with Setting studies
View Count: 505
[2020-12-28 16:14:26]
User123887 - Posts: 2
Can you tell me where I can remove the continuation lines between each new trading day, I find it unpleasant to have lines that overlap.
I would like it to be like the plots of the pivot points without a link between each day.
imageSierraChartExample.PNG / V - Attached On 2020-12-28 16:12:22 UTC - Size: 111.67 KB - 190 views
[2020-12-28 18:51:43]
John - SC Support - Posts: 37946
Change the Subgraph Draw Style to Dash. Refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
[2020-12-29 08:39:17]
Also refer to:
Chart Studies: Avoiding Vertical Joining Line for Study Subgraphs
