Date/Time: Wed, 19 Feb 2025 00:54:17 +0000
Draw Study Underneath Main Price Graph
View Count: 1359
[2020-12-28 16:01:47]
manfretto - Posts: 117
how to use 'Draw Study Underneath Main Price Graph' for two different indicators and price?
I use price bar, heatmap and volume threshold bubbles. How to put heatmap and volume threashold bubbles underneath price and also both visible? When I use option 'Draw Study Underneath Main Price Graph' in settings in the study section for volume bubbles it is not visible when heatmap is on. Is it possible to show volume bubbles Underneath price graph and above heatmap so I am able to see heatmap, bubbles and price at the same time?
[2020-12-28 17:59:39]
User907968 - Posts: 831
Yes, refer - https://www.sierrachart.com/index.php?page=doc/ChartStudies.html#StudyDisplayOrder, make sure heatmap appears before volume bubbles in study window.
imagemdhg_volume_dots.png / V - Attached On 2020-12-28 17:58:46 UTC - Size: 198.09 KB - 372 views
[2020-12-28 18:39:20]
It looks like the solution was as you suggested - to move up heatmap above volume bubbles in study window. Thank you.
[2021-01-08 14:39:03]
And how to make Volume profile above the price candles? Transparency does not work for price.
Enclosed it shows candles (1st layer) that distort view of volume profile.
imageBez nazwy.png / V - Attached On 2021-01-08 14:29:40 UTC - Size: 13.07 KB - 249 views
