Date/Time: Thu, 13 Feb 2025 20:20:34 +0000
Intraday / few days data only
View Count: 803
[2020-12-28 01:46:13] |
User859795 - Posts: 51 |
Hello, My futures daily chart won't load any more data than a few days. It happens after i reinstalled Sierra and used all the backup files. I went thru most of the regarding posts and helpfiles, but the chart still massed up. When i used the old install, i was able to load thousands of days on Daily chart using INTRADAY function, i cannot find this function amymore, also. Thank you, Zolie |
[2020-12-28 02:28:23] |
We see you are using CQG. Refer to this thread: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-28 04:06:10] |
Thank you! With CQG datafeed i'm getting 14 days of candles on the Daily ES chart. With Sierra Data i'm getting to 2019_09... How can i get more days on the daily chart when using as Intraday? Thank you, Zolie |
[2020-12-28 05:01:47] |
We see you have now activated the Denali exchange data feed but not an exchange. We have now activated the CME Group exchange for 3.25 USD per month. This is now done for your account. You now have access to all the available historical data. Make sure you have enabled this option: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) And then follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
