Date/Time: Tue, 18 Mar 2025 05:11:26 +0000
[User Discussion] - Volume based chart Weekly ECI VWAP
View Count: 2043
[2020-12-27 05:52:22] |
Hayden Glenn Barnes - Posts: 7 |
Hi, Am I able to have my weekly based ECI VWAP chart but using volume based candles, this isn't an issue with traditional products but I havent been able to make this work on a Bitcoin chart as the weekly close is different from traditional assets. I was able to change a weekly bar chart to the correct settings but this was only because I changed the settings to 7 days. Currently my volume based weekly chart the week ends 1 day early this throws out my studies completely. Regards Hayden |
[2021-01-01 14:39:21] |
m zamani rad - Posts: 24 |
Hi Hayden would you advise me how to setup weekly ECI VWAP for EMINI please. Thank you |
[2021-01-01 20:11:25] |
Sure. Add Custom studies- ECIVwapV1.5 is the one I use. Settings period type - Weekly or what ever periodicity you desire |
[2021-01-06 11:48:08] |
Thank you for your help.
[2022-09-22 04:49:20] |
User259893 - Posts: 1 |
Has this been solved? Having the same issue and I'm still searching for a solution
