Date/Time: Thu, 13 Feb 2025 19:47:18 +0000
Can I connect TD Ameritrade acc on SC?
View Count: 946
[2020-12-26 21:57:12] |
Spartan79 - Posts: 54 |
Hi. Can I connect my funded TD Ameritrade account on SC? I found some old posts about it, but nothing recent. Is this still supported? If so how would I go about it. Thank you. |
[2020-12-26 22:16:19] |
No TD Ameritrade is no longer supported. Refer to this page for the list of supported services. Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-26 22:16:59
