Date/Time: Thu, 13 Feb 2025 20:03:25 +0000
SC with Windows 7 or Windows 10
View Count: 504
[2020-12-26 19:25:07]
tobi - Posts: 351
Is there a difference in using SC with Microsoft Windows 7 (Pro, 64 bit) or Windows 10 (Pro, 64 bit)?
Which one would you recommend?
[2020-12-26 22:24:29]
No difference from the perspective of Sierra Chart. Personally we definitely think Windows 7 is better.
Windows 10 should not be trusted and is definitely part of all of this new world order/tyranny effort. But then again probably Windows 7 cannot be trusted either.
Date Time Of Last Edit: 2020-12-26 22:25:00
