Date/Time: Thu, 13 Feb 2025 19:57:15 +0000
i created a stydy which sends ...
View Count: 521
[2020-12-25 18:31:25] |
User39772 - Posts: 311 |
Hello, i created a stydy which sends an email via play sound if my entry criterion is hit. Every time I restart SC for every Trigger in the past douzend of email are sent. How can I avoid this, i.e. how can i make sure that the study does not send emails while loading ? |
[2020-12-26 08:01:20] |
Refer to this section here: ACSIL Programming Concepts: Not Performing Calculation/Processing during Historical Data Downloading or Full Recalculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-27 20:44:34] |
Unfortunately this does not work. I put it in front of my command as follows: //Wait until Chartbook is loaded if (sc.IsFullRecalculation || sc.DownloadingHistoricalData) return; sc.PlaySound(1); Alert #1 which also sends e-mails, still sends e-mails for every signal in the past every time I restart sc, e.g. when I compiled the dll. |
