Date/Time: Thu, 13 Feb 2025 19:47:02 +0000
Cant access Trade Settings?
View Count: 477
[2020-12-24 15:43:17] |
User951413 - Posts: 13 |
Why wont the General Trade Settings and the Chart Trade Settings window open when I select them either in the Global Setting or the Trade Settings?
[2020-12-24 16:28:47] |
Restart Sierra Chart. Do not open any of the settings windows and then select Window >> Reset Windows. After that try again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-24 16:29:04
