Date/Time: Thu, 13 Feb 2025 21:57:17 +0000
tick
View Count: 666
[2020-12-24 03:29:46] |
User765836 - Posts: 3 |
I checked the chart by displaying 1tick chart, but it looks like the chart is moving every few ticks instead of every 1tick. Is it possible to change it so that it moves every 1tick? The Intraday Data Strage Time Unit is set to 1 tick. Data feed: FXCM |
[2020-12-24 05:52:54] |
We need a precise explanation of what you mean by this: is moving every few ticks instead of every 1tick.
[2020-12-24 06:11:49] |
It's a bit clunky. I want it to move smoothly.
Date Time Of Last Edit: 2020-12-29 09:58:52
[2020-12-26 07:53:31] |
Please avoid providing videos: Support Board Posting Information: Do Not Post Videos Unless Requested! We are definitely sure there is not a problem. Refer to this help topic: Prices / Data Falling Behind: 4.10 - Market Not Active Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-29 10:01:11] |
I found the cause. It was because of Chart Update Interval setting. https://www.sierrachart.com/index.php?page=doc/helpdetails4.html#h4.2 Thank you for your time. |
