Date/Time: Mon, 25 Nov 2024 14:39:48 +0000
datefeed
View Count: 1015
[2014-02-18 21:28:48] |
User92938 - Posts: 3 |
Hi, id like to know some ... If I make update of SCH to courently version, there is not historical intraday date tick by tick for numbers bars. There is just historical date. I need date feet for symbols YM, ES, NQ and EMD. Now i need just for replay, so its not important for me real time. But I need corectly numbers bars(footprints) bid ask numbers date feed. And in previous version there are Intraday historical date, but in start, sometime said - "download failed" and than function. So my question is... if I pay packeg 5, can I use it for "replay"(not real trading) like credible tick by tick date like up to now? and Or somthing change in near future, thanks a lot pavel . |
[2014-02-18 22:12:52] |
Historical tick by tick data is available in the new versions for the symbols you have given. Refer to these notes for version 1091 and higher: The SC Historical Intraday Futures Data service has been removed. It is necessary now to use the service named SC Historical Data instead. The Sierra Chart Historical Data Service (SC Historical Data) has been enhanced to provide high-quality tick by tick data for the popular futures contracts from the CME, ICE and EUREX exchanges. The data is only delayed 10 to 15 minutes. When using the SC Historical Data service, the year portion of a futures contract symbol needs to consist of 2 digits. Example ESH14. And some symbols are different compared to the SC Historical Intraday Futures Data service. Therefore, you will need to update the symbols of your charts if you were previously using the SC Historical Intraday Futures Data service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-18 22:13:30
