Date/Time: Sat, 12 Sep 2026 22:23:21 +0000
Numbers Bars Calculated Values Label Not Centered
View Count: 875
[2020-12-22 18:26:15]
User566851 - Posts: 20
Hi:
I was wondering if you could help me solve the issue of these labels being off centered in the label box (see bottom right corner)? Even if I expand the right side of the chart they are off center. Thanks for the help.
Screenshot: http://www.sierrachart.com/image.php?Image=1608661469120.png
-Rob
[2020-12-22 19:28:29]
John - SC Support - Posts: 47854
They are not off-center. Within the code they are set to be aligned to the right-side of the chart and they are also set to not have the colon (:) after the name when they are on the right, so they are being drawn properly for where they are coded to be drawn.
But, we have made a change to move them by one character to the left so it is a cleaner look. This will be in the next release.
