Date/Time: Thu, 13 Feb 2025 20:28:59 +0000
real time data needed
View Count: 545
[2020-12-22 15:07:24] |
User102314 - Posts: 3 |
it appears i'm on a 10 minute delay on my live account. How do I change this to real time? |
[2020-12-22 15:47:54] |
John - SC Support - Posts: 37940 |
You would need to activate the data feed(s) for the data you want. If you are only looking for data from the CME Group, then you would just need the Denali Exchange Data Feed. You will find the information regarding this data feed along with Setup Instructions on this page: Denali Exchange Data Feed If you need data from any other source, then refer to the information for the Sierra Chart Exchange Data Feed here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
