Date/Time: Thu, 13 Feb 2025 20:00:35 +0000
How to Remove previous trade details from chart
View Count: 1435
[2020-12-22 14:51:35] |
User990945 - Posts: 4 |
Hello Sierra Support, I'm still learning the Sierra Chart platform and I'm in simulation mode. I closed out some previous trades but the trade details are still on my chart (i.e price entries, stop loss, take profit, etc.) How do I remove these previous trade details? Thanks, Jay Johnson |
Private File |
[2020-12-22 15:44:34] |
John - SC Support - Posts: 37939 |
If you just want to completely remove all previous trade data, then refer to the following: Trade Menu: Clear Trade Simulation Orders & Data (Trade menu) If you just want to not show the Order Fill markers, then refer to the following: Trade Menu: Show Order Fills (Trade menu) And if you want to change what is displayed with the Order Fills, then refer to the documentation starting here: Global Trade Settings Windows: Display Fill Text (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-22 15:54:33] |
Thanks, I just followed the instructions and the previous trade details were removed from my chart. Just curious, I would like to know if I can remove the trade details from my chart but still keep the trade activity within the log?
[2020-12-22 15:56:55] |
That would be removing the display of the Order Fills from the chart. Refer to the 2nd link given above.
[2020-12-22 16:21:06] |
Okay thanks John!
