Date/Time: Thu, 13 Feb 2025 20:20:00 +0000
P/L & Net Profit/Loss(NPL) are WAY off
View Count: 624
[2020-12-22 14:43:12] |
User829824 - Posts: 2 |
I have been having an issue where my PL and NPL in the DOM are showing incorrect numbers. First, my P/L is not updating, no matter if it's a win or loss. My NPL does update but it shows a HUGE number relative to the actual transaction. For example, I just traded a 2 lot MES for a 5 tick win, which should show a 10tick or 2 pt 2 tick profit but it shows 80.50P! Same thing happens if I take a loss. I was having this issue on an older version (I think 2187) and upgraded yesterday to 2207 and it's the same. I also thought it was my local system because my clock was off by about 2 mins, but I replaced the battery in my motherboard and fixed that too, so the time is precise as well and I'm still having the issue. Any idea what's going on? Thanks, Randy |
[2020-12-22 16:54:30] |
Refer to: Help With Daily Profit/Loss Value Also make sure the currency value per tick setting is correct: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-22 16:54:45
