Date/Time: Thu, 13 Feb 2025 20:07:01 +0000
[Programming Help] - Inter & Intra Market Spread Chart Issue
View Count: 448
[2020-12-22 13:54:01]
User710204 - Posts: 2
Hi there,
I have some questions / issues if you can help please.
1) I am trying to create futures spread chart between AUD MAR 21 & GBP MAR 21(ratio difference). I created in Global Settings >> Symbol Settings, {ADH21}-{BPH21}, Uses Formula Operators setting to Yes. However, the chart did not load.
2) I did the same (above) with ES Futures between ES MAR 21 & ES JUN 21 - {ESH21}-{ESM21), this worked, chart showed up but only for 1 Min, 5 Min & 10 Min. However, the chart for 1H & Daily, no chart appear.
Please advise if I had miss out something / steps?
Thank you.
