Date/Time: Thu, 24 Sep 2026 12:44:38 +0000
Use Sierrachart on separate Lynx Account
View Count: 2474
| [2020-12-22 07:18:40] |
| User134797 - Posts: 56 |
Good Morning, I have a Sierrachart account for five(5)computers. I also have two(2)separate Lynx Account on two different computers. My question is: Can I use Sierrachart for two different Lynx Account? If possible, in what way? Regards, Iwan |
| [2020-12-22 15:13:56] |
| John - SC Support - Posts: 47994 |
What we see of Lynx is that it is using Interactive Brokers. If this is the case, then you should not have any problem connecting one Sierra Chart on each computer to the Interactive Brokers software that is also installed on that computer. Basically, you would just go through the Setup Instructions to connect Sierra Chart for each computer that you want to connect. Refer to the Setup Instructions here: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-22 15:45:11] |
In addition to the above response, also be aware of the information here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
