Date/Time: Thu, 13 Feb 2025 18:53:34 +0000
Footprint Colouring method
View Count: 519
[2020-12-21 15:35:20] |
steliosdrk - Posts: 15 |
Hey Guys. Regarding the Footprint i have a question. Iam able to set a bid/ask profile(column 1) with full backround(column 2) and i want the shading of the colouring to be derived from the Delta(Bid/Ask) Percentage on each price bar.The only option is the diagonal one,not each price bar.What am i missing here? Thanks. |
[2020-12-21 17:38:05] |
John - SC Support - Posts: 37937 |
Take a look at these the following coloring option and see if this will work for what want to do: Numbers Bars: Background Coloring Based on AskVol BidVol Difference Percentage of Max Dominant Side If you need something else, let us know the exact calculation you are looking for and we should be able to get into the software in about a week or so. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
