Date/Time: Thu, 13 Feb 2025 19:27:57 +0000
VbP & Numbers bar
View Count: 671
[2020-12-21 14:35:57]
User41512 - Posts: 58
Over this weekend there appears to have been some changes made by Sierra Charts which have affected the spacing for the VbP study bars & the numbers bars study.I attach a chartbook, with only these 2 charts. Please note the spacing on the numbers bar & VbP bars as of today (Monday 21st) on both. However, if you scroll back to an earlier date you will see the original set up for both studies. The change effects both the look & feel of the chart, but these are not changes I have made.
Please advise.
Thks
attachmentErrors.Cht - Attached On 2020-12-21 14:32:46 UTC - Size: 6.72 KB - 208 views
[2020-12-21 17:08:40]
John - SC Support - Posts: 37939
If there is a change in the spacing, then that is something that just needs to be changed by adjusting the scales for your charts. Refer to the following for Numbers Bars, which should also be applicable to what you are seeing for your Volume by Price charts:
Numbers Bars: Scaling a Numbers Bars Chart
