Date/Time: Thu, 13 Feb 2025 20:04:18 +0000
FDAX tick size change
View Count: 1539
[2020-12-21 10:53:22] |
User649641489846 - Posts: 17 |
Hi, FDAX tick size has changed from 0.5 to 1.0 as of Dec 21, 2020. Is this reflected in the data feed? When I check 'Chart-Chart Settings-Auto Set from Data Feed' it still gives the old tick size and under 'Chart Settings-Advanced Setting 2' the old currency value per tick. Please also see link below for details about this change. https://www.eurex.com/ex-en/find/circulars/circular-2069732 Thanks Jan |
[2020-12-21 14:03:01] |
We will get the tick size and value format updated for these symbols. Just give us about 30 minutes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-21 14:03:16
[2020-12-21 14:58:57] |
User90125 - Posts: 715 |
Eurex changed the FDAX to a full tick instrument today. So the minimum tick fluctuation is now 1 point on the FDAX, for 25 Euros. No more half-tick increments at 0.5 points for 12.5 Euros. More info here as well: https://www.eurex.com/ex-en/markets/idx/dax/DAX-Futures-139902 |
[2020-12-22 06:08:15] |
Refer to: Steps to Update Symbol Settings Related to EUREX Tick Size Changes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
