Date/Time: Fri, 18 Sep 2026 16:13:32 +0000
Unable to connect to Bitmex API
View Count: 1065
| [2020-12-21 08:12:52] |
| Aidas Kaspar - Posts: 5 |
I followed all the instructions for connecting sierra chart to the bitmex api but i cant get it to connect. Message log as follows: Reading Internal Order ID file. | 2020-12-19 11:02:15.434 Reading Trade Orders file. | 2020-12-19 11:02:15.475 Reading Trade Positions file. | 2020-12-19 11:02:15.476 Reading Account Balance file. | 2020-12-19 11:02:15.477 UDPListener (988). Port 22904 | Listening on UDP port 22904. | 2020-12-19 11:02:15.488 Software version: 2207 64-bit | 2020-12-19 11:02:15.488 Primary Thread ID: 10464 | 2020-12-19 11:02:15.488 Usage end date: 2021-01-19 | 2020-12-19 11:02:15.488 Enabled for: Advanced Features 2. | 2020-12-19 11:02:15.488 Enabled for: Sierra Chart Historical Data Service. | 2020-12-19 11:02:15.488 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-12-19 11:02:15.488 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-12-19 11:02:15.488 Current selected Data/Trading service: SC Data - All Services | 2020-12-19 11:02:15.488 Custom symbol settings values: enabled | 2020-12-19 11:02:15.488 Chart Update Interval: 500 | 2020-12-19 11:02:15.488 Intraday Data Storage Time Unit: 1 | 2020-12-19 11:02:15.488 Time Zone: +00:00:00 (UTC+00) | 2020-12-19 11:02:15.489 2020-12-19 11:02:15 Local computer time in UTC | 2020-12-19 11:02:15.489 2020-12-19 11:02:15 Local computer time in SC Time Zone | 2020-12-19 11:02:15.489 2020-12-19 11:02:24 Server time in UTC | 2020-12-19 11:02:15.489 Local computer UTC time and Server UTC time difference: 9 seconds. | 2020-12-19 11:02:15.489 Notice: Your computer's clock is off by 9 seconds. For help with this, press the 'Send for Analysis' button. | 2020-12-19 11:02:15.489 Program path: C:\SierraChart2\ | 2020-12-19 11:02:15.489 Data Files path: C:\SierraChart2\Data\ | 2020-12-19 11:02:15.489 OS Version Number: 6.1 | 2020-12-19 11:02:15.489 Locale Setting: C | 2020-12-19 11:02:15.489 DLLs: DivergenceDetector_64.dll, EndedAuction_64.dll, ExahustionDetector_64.dll, JoboPinch_64.dll, LinearRegressionLocation_64.dll, PivotLine_64.dll, PoorStructure_64.dll, PrevReferences_64.dll, PriceTickDivergence_64.dll, ProfilePeriods_64.dll, ProfileValue_64.dll, ReconstructedTape_64.dll, StatisticsBubbles_64.dll, TickStatistics_64.dll, UserContributedStudies_64.dll, VolumeComparison_64.dll, VolumeTickerComparison_64.dll | 2020-12-19 11:02:15.489 Allowed protected custom studies: | 2020-12-19 11:02:15.489 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-12-19 11:02:15.501 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:02:15.520 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-19 11:02:15.548 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-19 11:02:15.548 Received 5 login tokens. | 2020-12-19 11:02:15.629 Symbol settings MD5 received. Request ID: 1. | 2020-12-19 11:02:16.278 Requested symbol settings for service code scdataallservices. Request ID: 2. | 2020-12-19 11:02:16.278 Symbol settings received. Request ID: 2. | 2020-12-19 11:02:17.298 SC Data - All Services | Disconnected. | 2020-12-19 11:02:17.302 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:02:17.302 SC Data - All Services | Connected to server complete. | 2020-12-19 11:02:20.304 Triggering next historical data download in queue. | 2020-12-19 11:02:20.304 Triggering next historical data download in queue. | 2020-12-19 11:02:20.304 Triggering next historical data download in queue. | 2020-12-19 11:02:20.304 Triggering next historical data download in queue. | 2020-12-19 11:02:20.304 SC Data - All Services | Disconnected. | 2020-12-19 11:06:33.992 Symbol settings could not be loaded because there are no applicable files to load. | 2020-12-19 11:06:33.993 Requested symbol settings for service code bitmex.exchange.trading. Request ID: 3. | 2020-12-19 11:06:33.993 SC Data - All Services | Disconnected. | 2020-12-19 11:06:33.999 Current selected Data/Trading service: BitMEX Trading Direct | 2020-12-19 11:06:34.002 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:06:34.036 Symbol settings received. Request ID: 3. | 2020-12-19 11:06:34.148 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:06:37.046 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:06:37.046 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:06:37.131 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:06:37.131 BitMEX Trading Direct socket (1) | Connecting to IP: 52.214.17.210. | 2020-12-19 11:06:37.131 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:06:37.181 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:06:37.181 BitMEX Trading Direct | Server header | HTTP/1.1 101 Switching Protocols | 2020-12-19 11:06:37.327 BitMEX Trading Direct | Server header | Date: Sat, 19 Dec 2020 11:06:46 GMT | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | Connection: upgrade | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTG=h6xPAN3W7jVzCOGsfyrmiRpo8fFwI+lLftkufOrtcfRonldMpaX2+Zk/o1jupEqhrHSJH2KrOyVwhMk0r+WZablrdZ0eFEr/Nqc8Z+6oskHempGU4ZMzOEcc4mtenNGOt3Q6/YXFp/TY523ZuEW9jl2POp/zBrz5MpZmEIF9EoLc; Expires=Sat, 26 Dec 2020 11:06:46 GMT; Path=/ | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTGCORS=h6xPAN3W7jVzCOGsfyrmiRpo8fFwI+lLftkufOrtcfRonldMpaX2+Zk/o1jupEqhrHSJH2KrOyVwhMk0r+WZablrdZ0eFEr/Nqc8Z+6oskHempGU4ZMzOEcc4mtenNGOt3Q6/YXFp/TY523ZuEW9jl2POp/zBrz5MpZmEIF9EoLc; Expires=Sat, 26 Dec 2020 11:06:46 GMT; Path=/; SameSite=None; Secure | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | upgrade: websocket | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | sec-websocket-accept: fLQqO5seYFbuftwaGqECDYgqvwM= | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | sec-websocket-version: 13 | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | websocket-server: uWebSockets | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | Strict-Transport-Security: max-age=31536000; includeSubDomains | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Server header | | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Web socket state is now open. | 2020-12-19 11:06:37.329 BitMEX Trading Direct | Connected to server complete. | 2020-12-19 11:06:37.329 Triggering next historical data download in queue. | 2020-12-19 11:06:37.329 Triggering next historical data download in queue. | 2020-12-19 11:06:37.329 Triggering next historical data download in queue. | 2020-12-19 11:06:37.329 Triggering next historical data download in queue. | 2020-12-19 11:06:37.329 BitMEX Trading Direct | ~~~ debug Orders http response: ~~~ | 2020-12-19 11:06:42.533 BitMEX Trading Direct | {"error":{"message":"Your account has been disabled from using the API. Please contact support.","name":"HTTPError"}} | 2020-12-19 11:06:42.533 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:42.728 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:42.926 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.119 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.310 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.518 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.704 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.894 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.096 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.280 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.484 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.672 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.863 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.055 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.248 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.442 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.625 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.829 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.022 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.023 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.219 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.410 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.594 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.787 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.974 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.179 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.364 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.543 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.739 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.932 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.123 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.328 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.517 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.697 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.893 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.084 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.286 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.490 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.688 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.689 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.879 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.077 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.077 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.077 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.078 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.078 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.078 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.078 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.078 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.078 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.274 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.464 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.656 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.842 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.041 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.230 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.413 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.593 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.791 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.985 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.177 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.367 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.560 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.744 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.939 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.136 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.321 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.510 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.702 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.891 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.074 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.266 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.463 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.658 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.858 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:55.052 * BitMEX Trading Direct | Forbidden HTTP response received. | 2020-12-19 11:06:55.234 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:06:55.234 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:06:55.234 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:06:55.234 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:06:55.234 BitMEX Trading Direct socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-12-19 11:06:55.234 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:06:55.235 BitMEX Trading Direct socket (1) | Write has completed. Shutdown being performed. | 2020-12-19 11:06:55.281 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:06:55.281 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:27.756 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:27.756 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:27.757 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:27.757 BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:27.757 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:27.807 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:27.807 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:27.952 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:27.952 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:27.952 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:27.952 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:27.952 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:27.972 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:27.972 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:27.972 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:27.972 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:27.972 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:27.972 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:27.972 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:28.016 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:28.016 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:30.978 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:30.978 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:30.978 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:30.979 BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:30.979 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:31.031 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:31.031 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:31.176 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:31.176 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:31.176 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:31.176 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:31.176 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:31.186 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:31.186 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:31.186 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:31.186 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:31.186 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:31.186 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:31.186 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:31.231 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:31.231 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:34.187 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:34.187 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:34.188 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:34.188 BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:34.188 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:34.237 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:34.237 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:34.377 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:34.377 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:34.377 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:34.377 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:34.377 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:34.397 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:34.397 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:34.397 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:34.397 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:34.397 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:34.397 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:34.397 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:34.439 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:34.439 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:37.405 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:37.405 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:37.406 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:37.406 BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:37.406 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:37.455 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:37.455 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:37.598 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:37.598 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:37.598 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:37.598 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:37.598 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:37.608 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:37.608 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:37.608 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:37.608 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:37.608 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:37.608 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:37.608 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:37.652 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:37.652 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:40.618 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:40.618 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:40.618 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:40.619 BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:40.619 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:40.674 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:40.674 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:40.828 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:40.828 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:40.828 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:40.828 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:40.828 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:40.833 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:40.833 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:40.833 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:40.833 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:40.833 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:40.833 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:40.833 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:40.879 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:40.879 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:43.847 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:43.847 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:43.972 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:43.973 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:43.973 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:44.022 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:44.022 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:44.167 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:44.167 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:44.167 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:44.167 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:44.167 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:44.177 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:44.177 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:44.177 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:44.177 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:44.177 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:44.177 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:44.177 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:44.219 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:44.219 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:47.183 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:47.183 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:47.184 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:47.184 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:47.184 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:47.239 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:47.239 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:47.395 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:47.395 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:47.395 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:47.395 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:47.395 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:47.405 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:47.405 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:47.405 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:47.405 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:47.405 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:47.405 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:47.405 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:47.450 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:47.450 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:50.411 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:50.411 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:50.412 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:50.412 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:50.412 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:50.462 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:50.462 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:50.606 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:50.606 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:50.606 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:50.606 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:50.606 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:50.616 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:50.616 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:50.616 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:50.616 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:50.616 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:50.616 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:50.616 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:50.659 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:50.659 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:53.625 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:53.625 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:53.626 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:53.626 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:53.626 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:53.681 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:53.681 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:53.831 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:53.831 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:53.831 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:53.831 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:53.831 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:53.844 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:53.844 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:53.844 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:53.844 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:53.844 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:53.844 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:53.844 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:53.889 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:53.889 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:56.858 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:56.858 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:56.858 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:56.859 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:56.859 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:56.914 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:56.914 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:57.053 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:57.053 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:57.053 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:57.053 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:57.053 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:57.063 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:57.063 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:57.063 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:57.063 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:57.063 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:57.063 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:57.063 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:57.105 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:57.105 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:00.067 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:00.067 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:00.068 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:00.069 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:00.069 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:00.121 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:00.121 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:00.259 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:00.259 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:00.259 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:00.259 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:00.259 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:00.279 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:00.279 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:00.279 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:00.279 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:00.279 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:00.279 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:00.279 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:00.322 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:00.322 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:03.286 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:03.286 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:03.287 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:03.287 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:03.287 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:03.347 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:03.347 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:03.493 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:03.493 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:03.493 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:03.493 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:03.493 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:03.503 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:03.503 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:03.503 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:03.503 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:03.503 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:03.503 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:03.503 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:03.548 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:03.548 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:06.515 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:06.515 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:06.516 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:06.516 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:06.516 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:06.569 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:06.569 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:06.721 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:06.721 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:06.721 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:06.721 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:06.721 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:06.735 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:06.735 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:06.735 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:06.735 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:06.735 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:06.735 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:06.735 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:06.782 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:06.782 BitMEX Trading Direct socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2020-12-19 11:09:09.652 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:09.652 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:09.744 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:09.744 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:09.745 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:09.745 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:09.745 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:09.795 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:09.795 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:09.937 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:09.937 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:09.937 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:09.937 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:09.937 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:09.943 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:09.943 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:09.943 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:09.943 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:09.943 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:09.943 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:09.943 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:09.987 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:09.987 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:12.953 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:12.953 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:12.954 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:12.954 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:12.954 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:13.006 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:13.006 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:13.150 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:13.150 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:13.150 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:13.150 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:13.150 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:13.160 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:13.160 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:13.160 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:13.160 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:13.160 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:13.160 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:13.160 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:13.204 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:13.204 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:16.168 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:16.168 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:16.168 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:16.169 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:16.169 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:16.220 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:16.220 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:16.370 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:16.370 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:16.370 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:16.370 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:16.370 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:16.390 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:16.390 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:16.390 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:16.390 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:16.390 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:16.390 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:16.390 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:16.435 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:16.435 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:19.397 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:19.397 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:19.397 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:19.397 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:19.397 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:19.448 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:19.448 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:19.597 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:19.597 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:19.597 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:19.597 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:19.597 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:19.607 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:19.607 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:19.607 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:19.607 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:19.607 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:19.607 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:19.607 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:19.652 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:19.652 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:22.610 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:22.610 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:22.611 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:22.611 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:22.611 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:22.660 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:22.660 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:22.802 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:22.802 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:22.802 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:22.802 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:22.802 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:22.822 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:22.822 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:22.822 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:22.822 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:22.822 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:22.822 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:22.822 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:22.865 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:22.865 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:25.828 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:25.828 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:25.828 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:25.829 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:25.829 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:25.881 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:25.881 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:26.023 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:26.023 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:26.023 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:26.023 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:26.023 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:26.033 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:26.033 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:26.033 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:26.033 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:26.033 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:26.033 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:26.033 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:26.077 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:26.077 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:29.037 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:29.037 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:29.038 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:29.038 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:29.038 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:29.089 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:29.089 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:29.234 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:29.234 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:29.234 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:29.234 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:29.234 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:29.240 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:29.240 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:29.240 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:29.240 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:29.240 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:29.240 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:29.240 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:29.285 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:29.285 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:32.250 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:32.250 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:32.251 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:32.251 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:32.251 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:32.300 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:32.300 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:32.481 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:32.481 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:32.481 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:32.481 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:32.481 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:32.484 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:32.484 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:32.484 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:32.484 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:32.484 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:32.484 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:32.484 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:32.527 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:32.527 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:35.496 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:35.496 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:35.497 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:35.497 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:35.497 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:35.547 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:35.547 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:35.691 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:35.691 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:35.691 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:35.691 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:35.691 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:35.701 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:35.701 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:35.701 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:35.701 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:35.701 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:35.701 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:35.701 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:35.745 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:35.745 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:38.714 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:38.714 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:38.715 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:38.715 BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:38.715 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:38.763 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:38.763 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:38.902 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:38.902 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:38.902 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:38.902 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:38.902 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:38.912 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:38.912 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:38.912 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:38.912 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:38.912 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:38.912 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:38.912 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:38.956 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:38.956 BitMEX Trading Direct socket (1) | Deleting network socket now after delay. | 2020-12-19 11:09:39.653 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:41.927 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:41.927 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:41.928 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:41.928 BitMEX Trading Direct socket (1) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:41.928 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:41.979 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:41.979 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:42.138 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:42.138 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:42.138 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:42.138 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:42.138 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:42.148 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:42.148 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:42.148 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:42.148 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:42.148 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:42.148 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:42.148 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:42.194 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:42.194 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:45.153 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:45.153 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:45.270 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:45.270 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:45.270 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:45.321 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:45.321 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:45.473 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:45.473 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:45.473 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:45.473 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:45.473 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:45.480 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:45.480 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:45.480 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:45.480 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:45.480 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:45.480 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:45.480 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:45.527 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:45.527 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:48.490 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:48.490 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:48.490 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:48.491 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:48.491 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:48.541 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:48.541 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:48.686 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:48.686 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:48.686 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:48.686 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:48.686 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:48.693 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:48.693 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:48.693 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:48.693 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:48.693 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:48.693 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:48.693 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:48.737 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:48.737 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:51.705 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:51.705 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:51.705 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:51.706 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:51.706 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:51.756 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:51.756 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:51.901 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:51.901 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:51.901 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:51.901 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:51.901 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:51.911 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:51.911 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:51.911 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:51.911 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:51.911 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:51.911 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:51.911 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:51.956 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:51.956 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:54.922 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:54.922 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:54.922 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:54.923 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:54.923 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:54.971 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:54.971 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:55.109 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:55.110 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:55.110 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:55.110 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:55.110 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:55.130 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:55.130 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:55.130 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:55.130 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:55.130 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:55.130 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:55.130 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:55.173 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:55.173 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:58.131 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:58.131 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:58.132 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:58.132 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:58.132 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:58.183 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:58.183 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:58.330 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:58.330 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:58.330 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:58.330 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:58.330 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:58.340 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:58.340 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:58.340 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:58.340 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:58.340 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:58.340 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:58.340 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:58.385 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:58.385 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:01.346 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:01.346 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:01.347 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:01.347 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:01.347 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:01.395 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:01.395 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:01.537 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:01.537 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:01.537 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:01.537 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:01.537 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:01.557 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:01.557 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:01.557 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:01.557 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:01.557 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:01.557 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:01.557 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:01.600 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:01.600 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:04.558 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:04.558 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:04.558 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:04.559 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:04.559 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:04.607 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:04.607 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:04.750 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:04.750 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:04.750 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:04.750 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:04.750 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:04.770 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:04.770 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:04.770 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:04.770 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:04.770 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:04.770 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:04.770 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:04.813 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:04.813 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:07.772 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:07.772 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:07.772 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:07.773 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:07.773 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:07.822 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:07.822 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:07.968 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:07.968 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:07.968 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:07.968 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:07.968 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:07.978 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:07.978 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:07.978 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:07.978 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:07.978 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:07.978 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:07.978 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:08.022 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:08.022 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:10.985 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:10.985 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:10.986 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:10.986 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:10.986 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:11.060 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:11.060 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:11.314 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:11.314 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:11.314 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:11.314 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:11.314 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:11.329 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:11.329 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:11.329 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:11.329 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:11.329 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:11.329 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:11.329 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:11.384 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:11.384 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:14.340 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:14.340 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:14.341 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:14.341 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:14.341 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:14.393 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:14.393 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:14.549 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:14.549 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:14.549 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:14.549 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:14.549 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:14.559 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:14.559 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:14.559 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:14.559 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:14.559 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:14.559 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:14.559 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:14.613 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:14.613 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:17.570 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:17.570 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:17.571 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:17.571 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:17.571 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:17.620 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:17.620 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:17.763 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:17.763 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:17.763 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:17.763 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:17.763 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:17.773 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:17.773 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:17.773 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:17.773 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:17.773 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:17.773 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:17.773 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:17.817 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:17.817 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:20.787 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:20.787 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:20.788 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:20.788 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:20.788 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:20.846 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:20.846 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:20.997 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:20.997 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:20.997 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:20.997 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:20.997 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:21.004 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:21.004 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:21.004 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:21.004 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:21.004 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:21.004 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:21.004 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:21.050 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:21.050 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:24.016 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:24.016 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:24.016 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:24.017 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:24.017 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:24.068 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:24.068 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:24.216 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:24.216 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:24.216 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:24.216 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:24.216 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:24.236 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:24.236 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:24.236 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:24.236 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:24.236 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:24.236 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:24.236 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:24.281 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:24.281 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:27.242 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:27.242 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:27.242 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:27.242 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:27.242 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:27.293 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:27.293 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:27.437 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:27.437 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:27.437 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:27.437 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:27.437 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:27.447 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:27.447 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:27.447 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:27.447 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:27.447 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:27.447 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:27.447 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:27.492 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:27.492 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:30.455 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:30.455 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:30.455 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:30.456 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:30.456 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:30.505 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:30.505 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:30.656 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:30.656 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:30.656 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:30.656 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:30.656 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:30.666 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:30.666 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:30.666 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:30.666 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:30.666 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:30.666 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:30.666 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:30.710 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:30.710 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:33.668 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:33.668 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:33.669 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:33.669 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:33.669 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:33.717 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:33.717 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:33.855 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:33.855 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:33.855 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:33.855 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:33.855 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:33.865 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:33.865 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:33.865 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:33.865 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:33.865 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:33.865 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:33.865 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:33.907 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:33.907 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:36.866 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:36.866 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:36.866 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:36.867 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:36.867 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:36.917 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:36.917 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:37.065 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:37.065 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:37.065 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:37.065 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:37.065 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:37.069 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:37.069 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:37.069 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:37.069 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:37.069 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:37.069 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:37.069 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:37.113 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:37.113 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:40.081 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:40.081 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:40.082 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:40.082 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:40.082 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:40.137 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:40.137 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:40.285 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:40.285 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:40.285 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:40.285 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:40.285 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:40.301 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:40.301 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:40.301 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:40.301 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:40.301 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:40.301 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:40.301 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:40.346 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:40.346 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:43.309 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:43.309 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:43.309 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:43.309 BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:43.309 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:43.362 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:43.362 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:43.511 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:43.511 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:43.511 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:43.511 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:43.511 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:43.521 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:43.521 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:43.521 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:43.521 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:43.521 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:43.521 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:43.521 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:43.565 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:43.565 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:46.524 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:46.524 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:46.600 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:46.600 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:46.600 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:46.651 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:46.651 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:46.790 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:46.790 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:46.790 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:46.790 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:46.790 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:46.810 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:46.810 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:46.810 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:46.810 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:46.810 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:46.810 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:46.810 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:46.852 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:46.852 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:49.819 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:49.819 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:49.819 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:49.820 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:49.820 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:49.875 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:49.875 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:50.023 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:50.023 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:50.023 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:50.023 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:50.023 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:50.033 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:50.033 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:50.033 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:50.033 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:50.033 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:50.033 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:50.033 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:50.078 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:50.078 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:53.048 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:53.048 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:53.049 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:53.049 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:53.049 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:53.099 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:53.099 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:53.242 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:53.242 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:53.242 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:53.242 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:53.242 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:53.253 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:53.253 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:53.253 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:53.253 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:53.253 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:53.253 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:53.253 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:53.297 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:53.297 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:56.257 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:56.257 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:56.258 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:56.258 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:56.258 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:56.307 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:56.307 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:56.447 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:56.447 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:56.447 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:56.447 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:56.447 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:56.467 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:56.467 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:56.467 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:56.467 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:56.467 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:56.467 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:56.467 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:56.510 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:56.510 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:59.472 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:59.472 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:59.472 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:59.473 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:59.473 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:59.523 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:59.523 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:59.667 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:59.667 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:59.667 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:59.667 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:59.667 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:59.674 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:59.674 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:59.674 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:59.674 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:59.674 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:59.674 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:59.674 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:59.718 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:59.718 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:11:02.684 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:11:02.684 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:11:02.684 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:11:02.685 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:11:02.685 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:11:02.735 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:11:02.735 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:11:02.884 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:11:02.884 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:02.884 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:11:02.884 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:02.884 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:11:02.894 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:11:02.894 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:02.894 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:02.894 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:11:02.894 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:11:02.894 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:02.894 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:11:02.939 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:11:02.939 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:11:05.898 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:11:05.898 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:11:05.898 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:11:05.899 BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:11:05.899 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:11:05.947 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:11:05.947 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:11:06.088 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:11:06.088 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:06.088 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:11:06.088 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:06.088 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:11:06.108 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:11:06.108 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:06.108 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:06.108 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:11:06.108 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:11:06.108 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:06.108 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:11:06.150 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:11:06.150 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:13:06.112 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:13:06.112 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:13:06.263 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:13:06.263 BitMEX Trading Direct socket (1) | Connecting to IP: 34.242.202.239. | 2020-12-19 11:13:06.263 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:13:06.314 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:13:06.314 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:13:06.456 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:13:06.456 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:13:06.456 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:13:06.456 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:13:06.456 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:13:06.476 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:13:06.476 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:13:06.476 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:13:06.476 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:13:06.476 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:13:06.476 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:13:06.476 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:13:06.519 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:13:06.519 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:15:06.486 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:15:06.486 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:15:06.603 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:15:06.603 BitMEX Trading Direct socket (1) | Connecting to IP: 52.213.82.212. | 2020-12-19 11:15:06.603 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:15:06.654 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:15:06.654 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:15:06.798 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:15:06.798 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:15:06.798 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:15:06.798 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:15:06.798 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:15:06.818 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:15:06.818 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:15:06.818 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:15:06.818 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:15:06.818 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:15:06.818 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:15:06.818 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:15:06.862 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:15:06.862 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:17:06.823 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:17:06.823 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:17:06.904 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:17:06.905 BitMEX Trading Direct socket (1) | Connecting to IP: 52.208.32.240. | 2020-12-19 11:17:06.905 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:17:06.953 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:17:06.953 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:17:07.095 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:17:07.095 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:17:07.095 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:17:07.095 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:17:07.095 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:17:07.105 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:17:07.105 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:17:07.105 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:17:07.105 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:17:07.105 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:17:07.105 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:17:07.105 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:17:07.149 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:17:07.149 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:19:07.115 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:19:07.115 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:19:07.116 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:19:07.116 BitMEX Trading Direct socket (1) | Connecting to IP: 54.246.209.249. | 2020-12-19 11:19:07.116 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:19:07.191 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:19:07.191 BitMEX Trading Direct | Server header | HTTP/1.1 101 Switching Protocols | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | Date: Sat, 19 Dec 2020 11:19:16 GMT | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | Connection: upgrade | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTG=FY1/3+fk1vDq0+8bRPuFIY6fZbjSd0B9tKhyWwEe8xwukw1k0YR3mWcgvg+KX0GvzFRqM5PsXMX9zItNpkvMb07ddZWcJhr5ff1RoZbylls7dQyH42AKY5/JexroSXTRfX0GdlTGvwdF7yur7v7bluttPRXJHKDt2KmPCdeJtFHR; Expires=Sat, 26 Dec 2020 11:19:16 GMT; Path=/ | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTGCORS=FY1/3+fk1vDq0+8bRPuFIY6fZbjSd0B9tKhyWwEe8xwukw1k0YR3mWcgvg+KX0GvzFRqM5PsXMX9zItNpkvMb07ddZWcJhr5ff1RoZbylls7dQyH42AKY5/JexroSXTRfX0GdlTGvwdF7yur7v7bluttPRXJHKDt2KmPCdeJtFHR; Expires=Sat, 26 Dec 2020 11:19:16 GMT; Path=/; SameSite=None; Secure | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | upgrade: websocket | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | sec-websocket-accept: HfQ0wXPa3VV0iaYZ8pRqKZXJzWA= | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | sec-websocket-version: 13 | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | websocket-server: uWebSockets | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | Strict-Transport-Security: max-age=31536000; includeSubDomains | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Server header | | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Web socket state is now open. | 2020-12-19 11:19:07.452 BitMEX Trading Direct | Connected to server complete. | 2020-12-19 11:19:07.452 Triggering next historical data download in queue. | 2020-12-19 11:19:07.453 Triggering next historical data download in queue. | 2020-12-19 11:19:07.453 Triggering next historical data download in queue. | 2020-12-19 11:19:07.453 Triggering next historical data download in queue. | 2020-12-19 11:19:07.453 BitMEX Trading Direct | ~~~ debug Orders http response: ~~~ | 2020-12-19 11:19:12.792 BitMEX Trading Direct | {"error":{"message":"Your account has been disabled from using the API. Please contact support.","name":"HTTPError"}} | 2020-12-19 11:19:12.792 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:13.130 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:13.462 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:13.792 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:14.124 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:14.443 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:14.763 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:15.103 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:15.432 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:15.754 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:16.537 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:16.849 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:17.168 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:17.169 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:17.481 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:17.790 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:18.097 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:18.407 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:18.713 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.036 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.353 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.664 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.975 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:20.320 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:20.655 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:20.656 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:20.976 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:21.294 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:21.606 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:21.926 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:22.248 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:22.249 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:22.570 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:22.892 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:23.204 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:23.522 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:23.838 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:24.143 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:24.460 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:24.774 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:25.092 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:25.400 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:25.704 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:26.120 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:26.518 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:26.827 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:27.159 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:27.480 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:27.814 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:28.131 * BitMEX Trading Direct | Forbidden HTTP response received. | 2020-12-19 11:19:28.432 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:19:28.432 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:19:28.432 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:19:28.432 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:19:28.432 BitMEX Trading Direct socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-12-19 11:19:28.432 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:19:28.432 BitMEX Trading Direct socket (1) | Write has completed. Shutdown being performed. | 2020-12-19 11:19:28.503 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:19:28.503 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:04.014 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:04.014 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:04.116 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:04.117 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:04.117 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:04.203 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:04.203 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:04.443 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:04.443 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:04.443 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:04.443 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:04.443 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:04.463 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:04.463 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:04.463 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:04.463 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:04.463 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:04.463 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:04.463 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:04.533 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:04.533 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:07.473 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:07.473 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:07.473 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:07.474 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:07.474 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:07.554 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:07.554 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:07.783 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:07.783 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:07.783 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:07.783 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:07.783 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:07.803 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:07.803 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:07.803 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:07.803 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:07.803 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:07.803 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:07.803 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:07.872 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:07.872 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:10.807 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:10.807 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:10.808 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:10.808 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:10.808 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:10.892 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:10.892 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:11.138 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:11.138 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:11.138 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:11.138 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:11.138 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:11.151 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:11.151 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:11.151 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:11.151 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:11.151 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:11.151 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:11.151 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:11.223 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:11.223 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:14.161 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:14.161 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:14.161 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:14.161 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:14.161 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:14.238 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:14.238 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:14.470 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:14.470 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:14.470 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:14.470 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:14.470 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:14.473 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:14.473 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:14.473 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:14.473 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:14.473 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:14.473 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:14.473 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:14.535 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:14.535 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:17.485 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:17.485 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:17.485 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:17.486 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:17.486 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:17.565 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:17.565 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:17.809 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:17.809 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:17.809 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:17.809 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:17.809 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:17.812 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:17.812 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:17.812 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:17.812 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:17.812 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:17.812 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:17.812 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:17.878 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:17.878 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:20.827 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:20.827 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:20.827 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:20.828 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:20.828 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:20.909 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:20.909 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:21.160 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:21.160 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:21.160 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:21.160 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:21.160 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:21.170 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:21.170 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:21.170 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:21.170 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:21.170 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:21.170 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:21.170 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:21.243 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:21.244 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:24.178 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:24.178 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:24.179 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:24.179 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:24.179 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:24.257 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:24.257 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:24.507 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:24.507 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:24.507 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:24.507 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:24.507 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:24.527 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:24.527 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:24.527 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:24.527 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:24.527 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:24.527 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:24.527 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:24.676 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:24.676 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:27.531 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:27.531 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:27.531 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:27.532 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:27.532 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:27.609 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:27.609 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:27.849 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:27.849 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:27.849 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:27.849 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:27.849 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:27.859 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:27.859 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:27.859 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:27.859 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:27.859 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:27.859 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:27.859 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:27.933 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:27.933 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:30.873 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:30.873 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:30.873 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:30.874 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:30.874 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:30.962 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:30.962 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:31.194 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:31.194 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:31.194 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:31.194 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:31.194 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:31.204 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:31.204 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:31.204 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:31.204 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:31.204 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:31.204 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:31.204 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:31.275 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:31.275 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:34.212 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:34.212 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:34.213 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:34.213 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:34.213 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:34.285 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:34.285 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:34.518 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:34.518 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:34.518 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:34.518 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:34.518 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:34.528 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:34.528 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:34.528 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:34.528 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:34.528 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:34.528 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:34.528 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:34.597 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:34.597 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:37.535 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:37.535 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:37.535 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:37.536 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:37.536 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:37.613 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:37.613 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:37.841 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:37.841 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:37.841 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:37.841 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:37.842 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:37.852 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:37.852 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:37.852 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:37.852 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:37.852 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:37.852 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:37.852 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:37.921 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:37.921 BitMEX Trading Direct socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2020-12-19 11:21:39.670 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:21:39.670 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:40.853 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:40.853 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:40.853 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:40.854 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:40.854 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:40.942 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:40.942 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:41.181 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:41.181 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:41.181 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:41.181 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:41.181 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:41.217 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:41.217 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:41.217 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:41.217 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:41.217 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:41.217 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:41.217 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:41.286 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:41.286 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:44.224 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:44.224 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:44.224 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:44.224 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:44.224 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:44.313 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:44.313 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:44.631 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:44.631 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:44.631 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:44.631 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:44.631 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:44.644 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:44.644 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:44.644 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:44.644 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:44.644 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:44.644 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:44.644 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:44.710 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:44.710 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:47.655 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:47.655 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:47.655 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:47.655 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:47.655 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:47.733 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:47.733 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:47.965 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:47.965 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:47.965 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:47.965 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:47.965 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:47.975 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:47.975 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:47.975 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:47.975 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:47.975 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:47.975 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:47.975 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:48.045 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:48.045 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:50.978 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:50.978 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:50.978 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:50.979 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:50.979 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:51.059 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:51.059 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:51.293 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:51.293 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:51.293 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:51.293 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:51.293 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:51.313 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:51.313 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:51.313 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:51.313 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:51.313 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:51.313 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:51.313 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:51.383 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:51.383 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:54.321 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:54.321 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:54.322 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:54.322 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:54.322 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:54.405 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:54.405 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:54.664 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:54.664 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:54.664 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:54.664 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:54.664 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:54.684 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:54.684 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:54.684 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:54.684 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:54.684 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:54.684 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:54.684 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:54.761 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:54.761 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:57.686 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:57.686 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:57.686 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:57.687 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:57.687 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:57.777 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:57.777 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:58.011 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:58.012 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:58.012 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:58.012 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:58.012 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:58.022 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:58.022 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:58.022 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:58.022 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:58.022 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:58.022 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:58.022 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:58.096 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:58.096 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:01.024 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:01.024 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:01.024 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:22:01.025 BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:22:01.025 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:01.109 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:01.109 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:01.369 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:01.369 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:01.369 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:01.369 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:01.369 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:22:01.383 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:01.383 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:01.383 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:01.383 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:01.383 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:01.383 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:01.383 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:22:01.448 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:22:01.448 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:04.394 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:04.394 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:04.469 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:22:04.469 BitMEX Trading Direct socket (2) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:04.469 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:04.553 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:04.553 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:04.801 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:04.801 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:04.801 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:04.801 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:04.801 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:22:04.821 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:04.821 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:04.821 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:04.821 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:04.821 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:04.821 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:04.821 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:22:04.896 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:22:04.896 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:07.825 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:07.825 BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:07.825 BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:22:07.826 BitMEX Trading Direct socket (2) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:07.826 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:07.912 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:07.912 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:08.152 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:08.152 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:08.152 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:08.152 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:08.152 BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:22:08.153 BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:08.153 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:08.153 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:08.153 BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:08.153 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:08.153 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:08.153 BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:22:08.221 BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:22:08.221 BitMEX Trading Direct socket (1) | Deleting network socket now after delay. | 2020-12-19 11:22:09.671 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:11.169 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:11.169 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:11.170 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:22:11.170 BitMEX Trading Direct socket (1) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:11.170 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:11.251 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:11.251 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:11.502 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:11.502 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:11.502 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:11.502 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:11.502 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:22:11.512 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:11.512 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:11.512 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:11.512 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:11.512 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:11.512 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:11.512 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:22:11.586 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:22:11.586 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:14.518 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:14.518 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:14.518 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:22:14.518 BitMEX Trading Direct socket (1) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:14.518 BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:14.598 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:14.598 BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:14.849 BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:14.849 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:14.849 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:14.849 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:14.849 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:22:14.869 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:14.869 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:14.869 BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:14.869 BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:14.869 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:14.869 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:14.869 BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:22:14.937 BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:22:14.937 File >> Disconnect selected. | 2020-12-19 11:22:15.642 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-12-19 11:22:15.642 BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:15.642 |
| [2020-12-21 13:21:08] |
| Calculus - Posts: 145 |
You have to now connect through - SC Data - All Services [data] The old Bitmex connection does not work, nor do I think Bitmex trading through Sierra, only the Bitmex data feed is now offered. If data is what you're after they also now have the Binance data feed but again no trading through Binance and there's not a lot of historical data. |
| [2020-12-21 20:07:29] |
This is definitely not correct: The old Bitmex connection does not work, nor do I think Bitmex trading through Sierra, only the Bitmex data feed is now offered.
BitMex trading is still supported. It has not changed. However, we are no longer helping with BitMex connection problems. However, we may remove BitMex trading support. So we recommend not using it or relying on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-21 20:53:30] |
Sorry for a stupid question, but if Bitmex trading is still supported on Sierra, but using their API doesn't work via a connection through the Bitmex server (like it used to do), how do you setup trading on Bitmex? Thanks |
| [2020-12-22 06:13:56] |
This is not something we can help with. We do not control those connections. You need to ask BitMex why their systems are not working properly but just do not do that. You are wasting your time. You are expressing the basic reason of why we are so adamantly against any type of connectivity that does not make complete sense, and we are not in complete control of. Otherwise, everyone gets frustrated here. This is why it is stupid for us to be supporting any trading with any crypto currency exchange and we will never do that again. We are seeing this again with Binance. Users have been asking about us supporting that, for market data, and we did not do it for years because it is a waste of our time and finally we finish it, and now what we see is problems. This is only reaffirming what we always knew. At this time, we are going to make a decision soon to pull support for BitMex. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-22 06:52:44] |
Engineering, this is fine. I only asked because you said Bitmex TRADING was available on Sierra then you say it's probably not as you don't control their connections. All I wanted was some clarity. |
| [2020-12-22 07:24:01] |
And for the record, we just tested our BitMex account in the test environment and the connection works just fine: BitMEX Trading Direct | Connecting to URI testnet.bitmex.com/realtime/WebSocket | 2020-12-22 02:23:07.462
BitMEX Trading Direct | Connecting to WebSocket server testnet.bitmex.com:443 | 2020-12-22 02:23:07.462 BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-22 02:23:07.510 BitMEX Trading Direct socket (1) | Send buffer size: 0 | 2020-12-22 02:23:07.511 BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-22 02:23:07.511 BitMEX Trading Direct socket (1) | Receive buffer size: 5242880 | 2020-12-22 02:23:07.512 BitMEX Trading Direct socket (1) | Connecting to IP: 54.77.60.127. | 2020-12-22 02:23:07.512 BitMEX Trading Direct | Opening WebSocket. | 2020-12-22 02:23:07.633 BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-22 02:23:07.634 BitMEX Trading Direct | GET /realtime/WebSocket HTTP/1.1 Host: testnet.bitmex.com:443 Upgrade: websocket Connection: Upgrade Sec-WebSocket-Key: AAAAAAAAAADzZZ/leAMAAA== Sec-WebSocket-Version: 13 | 2020-12-22 02:23:07.635 BitMEX Trading Direct | Server header | HTTP/1.1 101 Switching Protocols | 2020-12-22 02:23:07.980 BitMEX Trading Direct | Server header | Date: Tue, 22 Dec 2020 07:23:07 GMT | 2020-12-22 02:23:07.981 BitMEX Trading Direct | Server header | Connection: upgrade | 2020-12-22 02:23:07.982 BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTG=q2jChzCHvEMOmCn9mwG/igGW+PQG70/GRU9DrO9vB5H1c/FIrBeZMW8kcX5PUR+VNU47ULgqeMAr7LS8AJ9uTvwMvw2SxFSEub8N10enfJQ67OT5noDePd942cuqD826QqS5DK/P2XgrHUWx89DOJbCVFv5nKx0P6q85R5SGI0Wg; Expires=Tue, 29 Dec 2020 07:23:07 GMT; Path=/ | 2020-12-22 02:23:07.982 BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTGCORS=q2jChzCHvEMOmCn9mwG/igGW+PQG70/GRU9DrO9vB5H1c/FIrBeZMW8kcX5PUR+VNU47ULgqeMAr7LS8AJ9uTvwMvw2SxFSEub8N10enfJQ67OT5noDePd942cuqD826QqS5DK/P2XgrHUWx89DOJbCVFv5nKx0P6q85R5SGI0Wg; Expires=Tue, 29 Dec 2020 07:23:07 GMT; Path=/; SameSite=None; Secure | 2020-12-22 02:23:07.982 BitMEX Trading Direct | Server header | upgrade: websocket | 2020-12-22 02:23:07.983 BitMEX Trading Direct | Server header | sec-websocket-accept: +zXs1fLAR0l6v23kRsJycnWTT+U= | 2020-12-22 02:23:07.983 BitMEX Trading Direct | Server header | sec-websocket-version: 13 | 2020-12-22 02:23:07.983 BitMEX Trading Direct | Server header | websocket-server: uWebSockets | 2020-12-22 02:23:07.984 BitMEX Trading Direct | Server header | Strict-Transport-Security: max-age=31536000; includeSubDomains | 2020-12-22 02:23:07.984 BitMEX Trading Direct | Server header | | 2020-12-22 02:23:07.984 BitMEX Trading Direct | Web socket state is now open. | 2020-12-22 02:23:07.985 BitMEX Trading Direct | Connected to server complete. | 2020-12-22 02:23:07.986 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-22 15:07:11] |
| ForgivingComputers.com - Posts: 1238 |
I have seen similar issues connecting to BitMEX. The solution was to generate a new API key at BitMEX and put it into the Data/Trade Service Settings. YMMV.
| [2020-12-27 12:54:04] |
| Aidas Kaspar - Posts: 5 |
Thanks for the replies. I reconnected to my live account and it works fine and charting and DOM are working.
