Date/Time: Tue, 29 Sep 2026 11:20:21 +0000
[Programming Help] - Coloring bars if they are between two particular subgraphs
View Count: 1122
| [2020-12-20 16:18:48] |
| jeden8l - Posts: 48 |
Hello. Im a beginner trying to create a study alert. I need to change the color of the bar if price (C) is between two subgraphs. Color Bar Based On Alert Condition study will be used for further development, the [In:14= 0 or 1] will define the bars that can be used to search for buy or sell signal, but first of all I have to define the alert formula. Example of the subgraphs canal is below, I have 6 canals, 12 subgraphs on the chart all together. http://www.sierrachart.com/image.php?Image=1608480637965.png I'm assuming this can be done in two ways: 1. If (C) is below ID4.SG7 and above ID:5.SG7 2. Change bar color if (C) crosses ID:4.SG7, ID:5.SG7 etc. for all 12 subgraphs. I just need an alert formula please if anyone may help me. |
| [2020-12-20 17:38:45] |
Okay, I figured out how to define formula =AND
(C<ID4.SG7, C>ID5.SG7) but I had to put each formula alert for one canal to separate Color Bar Based On Alert Condition studies, it's 6 of them all together. Is any chance to put all 6 formulas for all 6 canals in one Color Bar Based On Alert Condition study so the future algo will have to check In:14 in one study only? |
| [2020-12-21 17:36:24] |
| Sawtooth - Posts: 4355 |
To color the bar if any one of the formulas are true, combine the ANDs with OR:=OR(AND(C<ID4.SG7, C>ID5.SG7),AND(Condition2),,AND(Condition3),AND(Condition4),AND(Condition5),AND(Condition6)) |
