Date/Time: Mon, 25 Nov 2024 22:32:46 +0000
Trade Stats for Charts - position is duplicated
View Count: 2044
[2014-02-18 16:29:43]
DarthSidious - Posts: 63
I had this problem before, and it was fixed. Now the bug is back. For YM-201403-CBOT, I have 1 chart & 1 standalone DOM that I trade from. Right now my "Trade Stats for Charts" has 2 entries for YM-201403-CBOT, with Daily P/L listed. And the Live Totals summary row shows double the daily P&L
Using v 1088
Old thread: http://www.sierrachart.com/supportboard/showthread.php?t=42123
[2014-02-18 16:59:57]
Is this for Live or Simulated trading?
[2014-02-18 17:00:23]
Live
[2014-02-18 21:28:03]
Also, I should mention that after I have restarted my platform, I only see one row of YM-201403-CBOT and everything looks exactly the way it should
[2014-02-18 21:41:27]
This should be resolved in the latest Prerelease. So when you can, update and let us know if you still see a problem after.
[2014-02-18 22:07:39]
T44 - Posts: 363
Is this a duplicate of 1093 - trade stats for charts, show order fills on chart disappearing
See: http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=2082 noting the two rows for the same NG product, one showing fills, one without.
How does one update to prerelease for the non .NET /CLR version?
Date Time Of Last Edit: 2014-02-18 22:09:36
[2014-02-18 22:16:19]
We do not know the answer to your first question. There is too much analysis involved to answer the question and we will not do that. It is only confusing this thread to be posting in here. You are adding confusion for the user, and for us. T44, please do not post further in this thread.
The non-CLR version is always the latest prerelease.
Date Time Of Last Edit: 2014-02-18 22:17:07
[2014-02-18 23:16:59]
Do you mean the latest pre-release that is yet to be released? The current one "Download PreRelease Version - Version 1093 (Feb 17, 2014)" seems to be from before I posted this thread
[2014-02-19 22:43:52]
Please install version 1094 and let us know if you still see the problem.
This is the current version.
[2014-02-27 06:20:23]
Futures Operator - Posts: 239
On v1097, with Use Fill Calculated Positions-Global checked, still seeing duplicated position reporting in Live Trading, and in Market Replay, from multiple chart timeframes in Trade Stats for Charts.
http://screencast.com/t/narlr89x
1. Is it possible to set the Trade Stats for Charts tab to report positions by symbol rather than from all charts with trade lists?
2. Why is the Open P/L calculated some cents off?
3. What period of time does the Closed P/L field track?
[2014-02-27 07:35:35]
1. There should only be one row per symbol for the Non-simulated and Simulated sections. We need to see what the problem is.
However, a chart that is being replayed or has been replayed, will show separately because that data is different.
2. Refer to:
https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#RoundingError
3. This is documented here:
https://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#ChartTradeStatsTab
[2014-03-18 08:25:39]
Any update on this issue? I still experience it in live trading, v1103:
http://screencast.com/t/OlCAUoOMtVPy
Also, is it possible to save the setting for Show Only Working Orders or at least add an option to? It is an unnecessary step to set it every time if one only needs to see working orders.
[2014-03-18 08:28:21]
Update Sierra Chart to the latest release and let us know if you still see the duplicate symbols in the non-simulated section of the Trade Stats for Charts tab.
Date Time Of Last Edit: 2014-03-18 08:29:37
[2014-03-18 10:59:10]
Appears to be working correctly now, thank you.
[2014-03-18 19:27:27]
Al SC Developer - Posts: 434
Starting in ver 1109 this setting will be saved/restored.
[2014-03-20 13:41:15]
Thanks for adding the save working orders only setting!
The duplicate position bug seems to keep coming back, I believe it was fixed previously as well. This is on v1108:
http://screencast.com/t/OZiYkTMeeO
[2014-03-20 14:12:57]
Please verify the account for each of those lines is the same (not in your image). The live entries are added for unique symbol/account pairs.
[2014-03-20 14:16:57]
Yes the account shows the same on both duplicate lines. It is the same single live entry/trade on the same symbol, in the same account.
[2014-03-20 18:13:17]
^I thought the above was the case when I checked previously. However now I see one of the duplicate lines shows the Sim account, under the Live totals section.
[2014-03-20 18:15:22]
We will check on this.
