Date/Time: Thu, 13 Feb 2025 19:07:52 +0000
Addition of JPX stocks
View Count: 620
[2020-12-19 15:45:37] |
User462152 - Posts: 12 |
Hello. I recently learned about the Sierra Chart and felt that there was such a great tool, so I immediately registered. I feel the developer's seriousness in Sierra Chart's sophisticated and lean system, and I'm very excited to be able to use it. And the question, is it possible to handle Japanese stocks (additional brokers and tradable) on the Sierra Chart in the future? Currently, the tools of Japanese securities companies are very difficult to handle, and delays and various charts are difficult to use. As such, we are looking forward to the availability of useful tools such as the Sierra Chart for several Japanese traders. I think it will take some time to add new stocks that are not supported, but if you can afford it, I would be very happy if you could add it someday. Best regards. Date Time Of Last Edit: 2020-12-19 15:52:15
[2020-12-21 05:54:34] |
Do you require end of day data only for Japanese stocks? Or do you also require real-time data?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-21 05:54:40
[2020-12-21 06:27:25] |
It would be helpful if real-time data is also supported.
