Date/Time: Tue, 29 Sep 2026 05:51:44 +0000
[User Discussion] - Unable to connect to Bitmex API
View Count: 1164
[2020-12-19 11:36:04]
Aidas Kaspar - Posts: 5
I followed all the instructions for connecting sierra chart to the bitmex api but i cant get it to connect. Message log as follows:
Reading Internal Order ID file. | 2020-12-19 11:02:15.434
Reading Trade Orders file. | 2020-12-19 11:02:15.475
Reading Trade Positions file. | 2020-12-19 11:02:15.476
Reading Account Balance file. | 2020-12-19 11:02:15.477
UDPListener (988). Port 22904 | Listening on UDP port 22904. | 2020-12-19 11:02:15.488
Software version: 2207 64-bit | 2020-12-19 11:02:15.488
Primary Thread ID: 10464 | 2020-12-19 11:02:15.488
Usage end date: 2021-01-19 | 2020-12-19 11:02:15.488
Enabled for: Advanced Features 2. | 2020-12-19 11:02:15.488
Enabled for: Sierra Chart Historical Data Service. | 2020-12-19 11:02:15.488
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-12-19 11:02:15.488
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-12-19 11:02:15.488
Current selected Data/Trading service: SC Data - All Services | 2020-12-19 11:02:15.488
Custom symbol settings values: enabled | 2020-12-19 11:02:15.488
Chart Update Interval: 500 | 2020-12-19 11:02:15.488
Intraday Data Storage Time Unit: 1 | 2020-12-19 11:02:15.488
Time Zone: +00:00:00 (UTC+00) | 2020-12-19 11:02:15.489
2020-12-19 11:02:15 Local computer time in UTC | 2020-12-19 11:02:15.489
2020-12-19 11:02:15 Local computer time in SC Time Zone | 2020-12-19 11:02:15.489
2020-12-19 11:02:24 Server time in UTC | 2020-12-19 11:02:15.489
Local computer UTC time and Server UTC time difference: 9 seconds. | 2020-12-19 11:02:15.489
Notice: Your computer's clock is off by 9 seconds. For help with this, press the 'Send for Analysis' button. | 2020-12-19 11:02:15.489
Program path: C:\SierraChart2\ | 2020-12-19 11:02:15.489
Data Files path: C:\SierraChart2\Data\ | 2020-12-19 11:02:15.489
OS Version Number: 6.1 | 2020-12-19 11:02:15.489
Locale Setting: C | 2020-12-19 11:02:15.489
DLLs: DivergenceDetector_64.dll, EndedAuction_64.dll, ExahustionDetector_64.dll, JoboPinch_64.dll, LinearRegressionLocation_64.dll, PivotLine_64.dll, PoorStructure_64.dll, PrevReferences_64.dll, PriceTickDivergence_64.dll, ProfilePeriods_64.dll, ProfileValue_64.dll, ReconstructedTape_64.dll, StatisticsBubbles_64.dll, TickStatistics_64.dll, UserContributedStudies_64.dll, VolumeComparison_64.dll, VolumeTickerComparison_64.dll | 2020-12-19 11:02:15.489
Allowed protected custom studies: | 2020-12-19 11:02:15.489
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-12-19 11:02:15.501
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:02:15.520
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-19 11:02:15.548
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-19 11:02:15.548
Received 5 login tokens. | 2020-12-19 11:02:15.629
Symbol settings MD5 received. Request ID: 1. | 2020-12-19 11:02:16.278
Requested symbol settings for service code scdataallservices. Request ID: 2. | 2020-12-19 11:02:16.278
Symbol settings received. Request ID: 2. | 2020-12-19 11:02:17.298
SC Data - All Services | Disconnected. | 2020-12-19 11:02:17.302
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:02:17.302
SC Data - All Services | Connected to server complete. | 2020-12-19 11:02:20.304
Triggering next historical data download in queue. | 2020-12-19 11:02:20.304
SC Data - All Services | Disconnected. | 2020-12-19 11:06:33.992
Symbol settings could not be loaded because there are no applicable files to load. | 2020-12-19 11:06:33.993
Requested symbol settings for service code bitmex.exchange.trading. Request ID: 3. | 2020-12-19 11:06:33.993
SC Data - All Services | Disconnected. | 2020-12-19 11:06:33.999
Current selected Data/Trading service: BitMEX Trading Direct | 2020-12-19 11:06:34.002
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:06:34.036
Symbol settings received. Request ID: 3. | 2020-12-19 11:06:34.148
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:06:37.046
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:06:37.046
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:06:37.131
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:06:37.131
BitMEX Trading Direct socket (1) | Connecting to IP: 52.214.17.210. | 2020-12-19 11:06:37.131
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:06:37.181
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:06:37.181
BitMEX Trading Direct | Server header | HTTP/1.1 101 Switching Protocols | 2020-12-19 11:06:37.327
BitMEX Trading Direct | Server header | Date: Sat, 19 Dec 2020 11:06:46 GMT | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | Connection: upgrade | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTG=h6xPAN3W7jVzCOGsfyrmiRpo8fFwI+lLftkufOrtcfRonldMpaX2+Zk/o1jupEqhrHSJH2KrOyVwhMk0r+WZablrdZ0eFEr/Nqc8Z+6oskHempGU4ZMzOEcc4mtenNGOt3Q6/YXFp/TY523ZuEW9jl2POp/zBrz5MpZmEIF9EoLc; Expires=Sat, 26 Dec 2020 11:06:46 GMT; Path=/ | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTGCORS=h6xPAN3W7jVzCOGsfyrmiRpo8fFwI+lLftkufOrtcfRonldMpaX2+Zk/o1jupEqhrHSJH2KrOyVwhMk0r+WZablrdZ0eFEr/Nqc8Z+6oskHempGU4ZMzOEcc4mtenNGOt3Q6/YXFp/TY523ZuEW9jl2POp/zBrz5MpZmEIF9EoLc; Expires=Sat, 26 Dec 2020 11:06:46 GMT; Path=/; SameSite=None; Secure | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | upgrade: websocket | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | sec-websocket-accept: fLQqO5seYFbuftwaGqECDYgqvwM= | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | sec-websocket-version: 13 | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | websocket-server: uWebSockets | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | Strict-Transport-Security: max-age=31536000; includeSubDomains | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Server header | | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Web socket state is now open. | 2020-12-19 11:06:37.329
BitMEX Trading Direct | Connected to server complete. | 2020-12-19 11:06:37.329
Triggering next historical data download in queue. | 2020-12-19 11:06:37.329
BitMEX Trading Direct | ~~~ debug Orders http response: ~~~ | 2020-12-19 11:06:42.533
BitMEX Trading Direct | {"error":{"message":"Your account has been disabled from using the API. Please contact support.","name":"HTTPError"}} | 2020-12-19 11:06:42.533
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:42.728 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:42.926 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.119 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.310 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.518 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.704 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:43.894 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.096 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.280 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.484 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.672 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:44.863 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.055 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.248 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.442 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.625 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:45.829 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.022 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.023 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.219 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.410 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.594 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.787 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:46.974 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.179 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.364 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.543 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.739 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:47.932 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.123 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.328 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.517 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.697 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:48.893 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.084 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.286 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.490 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.688 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.689 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:49.879 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.077 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.077 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.077 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.078 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.078 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.078 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.078 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.078 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.078 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.274 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.464 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.656 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:50.842 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.041 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.230 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.413 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.593 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.791 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:51.985 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.177 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.367 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.560 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.744 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:52.939 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.136 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.321 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.510 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.702 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:53.891 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.074 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.266 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.463 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.658 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:54.858 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:06:55.052 *
BitMEX Trading Direct | Forbidden HTTP response received. | 2020-12-19 11:06:55.234
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:06:55.234
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:06:55.234
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:06:55.234
BitMEX Trading Direct socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-12-19 11:06:55.234
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:06:55.235
BitMEX Trading Direct socket (1) | Write has completed. Shutdown being performed. | 2020-12-19 11:06:55.281
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:06:55.281
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:27.756
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:27.756
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:27.757
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:27.757
BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:27.757
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:27.807
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:27.807
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:27.952
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:27.952
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:27.952
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:27.952
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:27.952
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:27.972
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:27.972
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:27.972
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:27.972
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:27.972
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:27.972
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:28.016
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:28.016
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:30.978
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:30.978
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:30.978
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:30.979
BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:30.979
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:31.031
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:31.031
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:31.176
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:31.176
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:31.176
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:31.176
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:31.176
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:31.186
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:31.186
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:31.186
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:31.186
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:31.186
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:31.186
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:31.231
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:31.231
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:34.187
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:34.187
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:34.188
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:34.188
BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:34.188
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:34.237
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:34.237
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:34.377
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:34.377
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:34.377
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:34.377
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:34.377
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:34.397
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:34.397
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:34.397
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:34.397
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:34.397
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:34.397
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:34.439
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:34.439
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:37.405
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:37.405
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:37.406
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:37.406
BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:37.406
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:37.455
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:37.455
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:37.598
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:37.598
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:37.598
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:37.598
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:37.598
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:37.608
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:37.608
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:37.608
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:37.608
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:37.608
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:37.608
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:37.652
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:37.652
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:40.618
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:40.618
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:40.618
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:40.619
BitMEX Trading Direct socket (2) | Connecting to IP: 52.208.54.24. | 2020-12-19 11:08:40.619
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:40.674
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:40.674
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:40.828
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:40.828
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:40.828
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:40.828
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:40.828
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:40.833
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:40.833
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:40.833
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:40.833
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:40.833
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:40.833
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:40.879
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:40.879
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:43.847
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:43.847
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:43.972
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:43.973
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:43.973
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:44.022
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:44.022
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:44.167
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:44.167
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:44.167
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:44.167
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:44.167
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:44.177
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:44.177
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:44.177
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:44.177
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:44.177
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:44.177
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:44.219
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:44.219
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:47.183
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:47.183
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:47.184
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:47.184
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:47.184
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:47.239
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:47.239
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:47.395
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:47.395
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:47.395
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:47.395
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:47.395
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:47.405
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:47.405
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:47.405
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:47.405
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:47.405
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:47.405
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:47.450
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:47.450
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:50.411
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:50.411
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:50.412
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:50.412
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:50.412
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:50.462
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:50.462
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:50.606
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:50.606
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:50.606
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:50.606
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:50.606
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:50.616
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:50.616
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:50.616
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:50.616
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:50.616
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:50.616
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:50.659
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:50.659
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:53.625
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:53.625
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:53.626
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:53.626
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:53.626
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:53.681
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:53.681
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:53.831
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:53.831
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:53.831
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:53.831
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:53.831
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:53.844
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:53.844
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:53.844
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:53.844
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:53.844
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:53.844
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:53.889
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:53.889
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:08:56.858
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:08:56.858
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:08:56.858
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:08:56.859
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:08:56.859
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:08:56.914
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:08:56.914
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:08:57.053
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:08:57.053
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:57.053
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:08:57.053
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:57.053
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:08:57.063
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:08:57.063
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:08:57.063
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:08:57.063
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:08:57.063
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:08:57.063
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:08:57.105
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:08:57.105
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:00.067
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:00.067
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:00.068
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:00.069
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:00.069
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:00.121
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:00.121
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:00.259
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:00.259
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:00.259
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:00.259
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:00.259
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:00.279
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:00.279
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:00.279
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:00.279
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:00.279
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:00.279
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:00.322
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:00.322
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:03.286
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:03.286
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:03.287
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:03.287
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:03.287
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:03.347
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:03.347
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:03.493
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:03.493
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:03.493
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:03.493
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:03.493
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:03.503
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:03.503
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:03.503
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:03.503
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:03.503
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:03.503
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:03.548
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:03.548
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:06.515
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:06.515
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:06.516
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:06.516
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:06.516
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:06.569
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:06.569
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:06.721
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:06.721
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:06.721
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:06.721
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:06.721
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:06.735
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:06.735
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:06.735
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:06.735
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:06.735
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:06.735
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:06.782
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:06.782
BitMEX Trading Direct socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2020-12-19 11:09:09.652
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:09.652
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:09.744
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:09.744
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:09.745
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:09.745
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:09.745
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:09.795
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:09.795
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:09.937
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:09.937
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:09.937
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:09.937
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:09.937
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:09.943
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:09.943
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:09.943
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:09.943
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:09.943
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:09.943
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:09.987
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:09.987
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:12.953
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:12.953
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:12.954
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:12.954
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:12.954
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:13.006
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:13.006
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:13.150
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:13.150
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:13.150
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:13.150
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:13.150
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:13.160
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:13.160
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:13.160
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:13.160
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:13.160
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:13.160
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:13.204
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:13.204
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:16.168
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:16.168
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:16.168
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:16.169
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:16.169
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:16.220
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:16.220
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:16.370
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:16.370
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:16.370
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:16.370
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:16.370
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:16.390
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:16.390
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:16.390
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:16.390
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:16.390
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:16.390
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:16.435
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:16.435
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:19.397
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:19.397
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:19.397
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:19.397
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:19.397
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:19.448
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:19.448
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:19.597
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:19.597
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:19.597
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:19.597
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:19.597
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:19.607
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:19.607
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:19.607
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:19.607
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:19.607
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:19.607
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:19.652
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:19.652
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:22.610
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:22.610
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:22.611
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:22.611
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:22.611
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:22.660
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:22.660
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:22.802
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:22.802
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:22.802
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:22.802
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:22.802
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:22.822
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:22.822
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:22.822
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:22.822
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:22.822
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:22.822
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:22.865
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:22.865
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:25.828
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:25.828
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:25.828
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:25.829
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:25.829
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:25.881
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:25.881
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:26.023
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:26.023
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:26.023
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:26.023
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:26.023
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:26.033
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:26.033
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:26.033
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:26.033
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:26.033
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:26.033
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:26.077
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:26.077
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:29.037
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:29.037
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:29.038
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:29.038
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:29.038
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:29.089
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:29.089
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:29.234
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:29.234
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:29.234
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:29.234
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:29.234
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:29.240
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:29.240
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:29.240
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:29.240
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:29.240
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:29.240
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:29.285
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:29.285
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:32.250
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:32.250
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:32.251
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:32.251
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:32.251
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:32.300
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:32.300
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:32.481
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:32.481
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:32.481
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:32.481
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:32.481
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:32.484
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:32.484
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:32.484
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:32.484
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:32.484
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:32.484
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:32.527
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:32.527
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:35.496
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:35.496
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:35.497
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:35.497
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:35.497
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:35.547
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:35.547
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:35.691
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:35.691
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:35.691
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:35.691
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:35.691
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:35.701
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:35.701
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:35.701
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:35.701
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:35.701
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:35.701
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:35.745
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:35.745
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:38.714
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:38.714
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:38.715
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:09:38.715
BitMEX Trading Direct socket (2) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:38.715
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:38.763
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:38.763
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:38.902
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:38.902
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:38.902
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:38.902
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:38.902
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:09:38.912
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:38.912
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:38.912
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:38.912
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:38.912
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:38.912
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:09:38.956
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:09:38.956
BitMEX Trading Direct socket (1) | Deleting network socket now after delay. | 2020-12-19 11:09:39.653
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:41.927
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:41.927
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:41.928
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:41.928
BitMEX Trading Direct socket (1) | Connecting to IP: 63.35.88.165. | 2020-12-19 11:09:41.928
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:41.979
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:41.979
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:42.138
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:42.138
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:42.138
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:42.138
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:42.138
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:42.148
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:42.148
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:42.148
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:42.148
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:42.148
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:42.148
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:42.194
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:42.194
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:45.153
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:45.153
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:45.270
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:45.270
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:45.270
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:45.321
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:45.321
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:45.473
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:45.473
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:45.473
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:45.473
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:45.473
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:45.480
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:45.480
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:45.480
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:45.480
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:45.480
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:45.480
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:45.527
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:45.527
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:48.490
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:48.490
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:48.490
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:48.491
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:48.491
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:48.541
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:48.541
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:48.686
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:48.686
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:48.686
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:48.686
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:48.686
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:48.693
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:48.693
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:48.693
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:48.693
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:48.693
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:48.693
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:48.737
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:48.737
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:51.705
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:51.705
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:51.705
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:51.706
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:51.706
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:51.756
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:51.756
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:51.901
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:51.901
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:51.901
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:51.901
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:51.901
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:51.911
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:51.911
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:51.911
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:51.911
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:51.911
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:51.911
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:51.956
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:51.956
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:54.922
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:54.922
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:54.922
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:54.923
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:54.923
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:54.971
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:54.971
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:55.109
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:55.110
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:55.110
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:55.110
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:55.110
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:55.130
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:55.130
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:55.130
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:55.130
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:55.130
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:55.130
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:55.173
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:55.173
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:09:58.131
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:09:58.131
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:09:58.132
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:09:58.132
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:09:58.132
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:09:58.183
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:09:58.183
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:09:58.330
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:09:58.330
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:58.330
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:09:58.330
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:58.330
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:09:58.340
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:09:58.340
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:09:58.340
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:09:58.340
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:09:58.340
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:09:58.340
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:09:58.385
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:09:58.385
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:01.346
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:01.346
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:01.347
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:01.347
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:01.347
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:01.395
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:01.395
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:01.537
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:01.537
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:01.537
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:01.537
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:01.537
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:01.557
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:01.557
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:01.557
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:01.557
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:01.557
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:01.557
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:01.600
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:01.600
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:04.558
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:04.558
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:04.558
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:04.559
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:04.559
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:04.607
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:04.607
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:04.750
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:04.750
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:04.750
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:04.750
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:04.750
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:04.770
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:04.770
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:04.770
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:04.770
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:04.770
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:04.770
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:04.813
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:04.813
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:07.772
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:07.772
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:07.772
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:07.773
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:07.773
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:07.822
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:07.822
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:07.968
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:07.968
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:07.968
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:07.968
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:07.968
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:07.978
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:07.978
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:07.978
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:07.978
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:07.978
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:07.978
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:08.022
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:08.022
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:10.985
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:10.985
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:10.986
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:10.986
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:10.986
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:11.060
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:11.060
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:11.314
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:11.314
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:11.314
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:11.314
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:11.314
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:11.329
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:11.329
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:11.329
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:11.329
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:11.329
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:11.329
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:11.384
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:11.384
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:14.340
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:14.340
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:14.341
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:14.341
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:14.341
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:14.393
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:14.393
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:14.549
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:14.549
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:14.549
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:14.549
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:14.549
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:14.559
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:14.559
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:14.559
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:14.559
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:14.559
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:14.559
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:14.613
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:14.613
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:17.570
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:17.570
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:17.571
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:17.571
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:17.571
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:17.620
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:17.620
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:17.763
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:17.763
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:17.763
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:17.763
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:17.763
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:17.773
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:17.773
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:17.773
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:17.773
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:17.773
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:17.773
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:17.817
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:17.817
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:20.787
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:20.787
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:20.788
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:20.788
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:20.788
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:20.846
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:20.846
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:20.997
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:20.997
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:20.997
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:20.997
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:20.997
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:21.004
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:21.004
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:21.004
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:21.004
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:21.004
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:21.004
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:21.050
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:21.050
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:24.016
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:24.016
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:24.016
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:24.017
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:24.017
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:24.068
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:24.068
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:24.216
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:24.216
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:24.216
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:24.216
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:24.216
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:24.236
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:24.236
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:24.236
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:24.236
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:24.236
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:24.236
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:24.281
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:24.281
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:27.242
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:27.242
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:27.242
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:27.242
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:27.242
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:27.293
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:27.293
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:27.437
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:27.437
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:27.437
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:27.437
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:27.437
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:27.447
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:27.447
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:27.447
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:27.447
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:27.447
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:27.447
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:27.492
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:27.492
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:30.455
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:30.455
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:30.455
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:30.456
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:30.456
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:30.505
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:30.505
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:30.656
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:30.656
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:30.656
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:30.656
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:30.656
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:30.666
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:30.666
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:30.666
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:30.666
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:30.666
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:30.666
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:30.710
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:30.710
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:33.668
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:33.668
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:33.669
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:33.669
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:33.669
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:33.717
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:33.717
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:33.855
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:33.855
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:33.855
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:33.855
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:33.855
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:33.865
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:33.865
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:33.865
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:33.865
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:33.865
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:33.865
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:33.907
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:33.907
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:36.866
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:36.866
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:36.866
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:36.867
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:36.867
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:36.917
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:36.917
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:37.065
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:37.065
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:37.065
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:37.065
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:37.065
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:37.069
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:37.069
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:37.069
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:37.069
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:37.069
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:37.069
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:37.113
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:37.113
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:40.081
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:40.081
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:40.082
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:40.082
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:40.082
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:40.137
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:40.137
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:40.285
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:40.285
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:40.285
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:40.285
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:40.285
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:40.301
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:40.301
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:40.301
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:40.301
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:40.301
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:40.301
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:40.346
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:40.346
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:43.309
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:43.309
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:43.309
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:43.309
BitMEX Trading Direct socket (1) | Connecting to IP: 54.228.62.141. | 2020-12-19 11:10:43.309
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:43.362
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:43.362
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:43.511
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:43.511
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:43.511
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:43.511
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:43.511
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:43.521
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:43.521
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:43.521
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:43.521
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:43.521
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:43.521
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:43.565
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:43.565
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:46.524
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:46.524
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:46.600
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:46.600
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:46.600
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:46.651
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:46.651
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:46.790
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:46.790
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:46.790
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:46.790
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:46.790
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:46.810
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:46.810
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:46.810
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:46.810
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:46.810
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:46.810
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:46.852
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:46.852
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:49.819
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:49.819
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:49.819
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:49.820
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:49.820
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:49.875
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:49.875
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:50.023
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:50.023
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:50.023
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:50.023
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:50.023
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:50.033
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:50.033
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:50.033
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:50.033
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:50.033
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:50.033
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:50.078
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:50.078
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:53.048
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:53.048
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:53.049
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:53.049
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:53.049
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:53.099
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:53.099
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:53.242
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:53.242
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:53.242
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:53.242
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:53.242
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:53.253
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:53.253
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:53.253
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:53.253
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:53.253
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:53.253
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:53.297
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:53.297
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:56.257
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:56.257
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:56.258
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:56.258
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:56.258
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:56.307
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:56.307
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:56.447
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:56.447
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:56.447
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:56.447
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:56.447
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:56.467
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:56.467
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:56.467
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:56.467
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:56.467
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:56.467
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:56.510
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:56.510
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:10:59.472
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:10:59.472
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:10:59.472
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:10:59.473
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:10:59.473
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:10:59.523
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:10:59.523
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:10:59.667
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:10:59.667
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:59.667
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:10:59.667
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:59.667
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:10:59.674
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:10:59.674
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:10:59.674
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:10:59.674
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:10:59.674
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:10:59.674
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:10:59.718
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:10:59.718
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:11:02.684
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:11:02.684
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:11:02.684
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:11:02.685
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:11:02.685
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:11:02.735
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:11:02.735
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:11:02.884
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:11:02.884
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:02.884
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:11:02.884
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:02.884
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:11:02.894
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:11:02.894
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:02.894
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:11:02.894
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:11:02.894
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:02.894
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:11:02.939
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:11:02.939
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:11:05.898
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:11:05.898
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:11:05.898
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:11:05.899
BitMEX Trading Direct socket (1) | Connecting to IP: 54.73.192.6. | 2020-12-19 11:11:05.899
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:11:05.947
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:11:05.947
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:11:06.088
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:11:06.088
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:06.088
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:11:06.088
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:06.088
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:11:06.108
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:11:06.108
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:11:06.108
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:11:06.108
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:11:06.108
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:11:06.108
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:11:06.150
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:11:06.150
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:13:06.112
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:13:06.112
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:13:06.263
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:13:06.263
BitMEX Trading Direct socket (1) | Connecting to IP: 34.242.202.239. | 2020-12-19 11:13:06.263
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:13:06.314
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:13:06.314
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:13:06.456
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:13:06.456
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:13:06.456
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:13:06.456
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:13:06.456
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:13:06.476
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:13:06.476
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:13:06.476
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:13:06.476
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:13:06.476
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:13:06.476
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:13:06.519
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:13:06.519
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:15:06.486
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:15:06.486
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:15:06.603
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:15:06.603
BitMEX Trading Direct socket (1) | Connecting to IP: 52.213.82.212. | 2020-12-19 11:15:06.603
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:15:06.654
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:15:06.654
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:15:06.798
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:15:06.798
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:15:06.798
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:15:06.798
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:15:06.798
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:15:06.818
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:15:06.818
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:15:06.818
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:15:06.818
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:15:06.818
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:15:06.818
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:15:06.862
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:15:06.862
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:17:06.823
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:17:06.823
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:17:06.904
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:17:06.905
BitMEX Trading Direct socket (1) | Connecting to IP: 52.208.32.240. | 2020-12-19 11:17:06.905
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:17:06.953
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:17:06.953
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:17:07.095
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:17:07.095
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:17:07.095
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:17:07.095
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:17:07.095
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:17:07.105
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:17:07.105
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:17:07.105
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:17:07.105
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:17:07.105
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:17:07.105
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:17:07.149
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:17:07.149
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:19:07.115
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:19:07.115
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:19:07.116
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:19:07.116
BitMEX Trading Direct socket (1) | Connecting to IP: 54.246.209.249. | 2020-12-19 11:19:07.116
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:19:07.191
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:19:07.191
BitMEX Trading Direct | Server header | HTTP/1.1 101 Switching Protocols | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | Date: Sat, 19 Dec 2020 11:19:16 GMT | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | Connection: upgrade | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTG=FY1/3+fk1vDq0+8bRPuFIY6fZbjSd0B9tKhyWwEe8xwukw1k0YR3mWcgvg+KX0GvzFRqM5PsXMX9zItNpkvMb07ddZWcJhr5ff1RoZbylls7dQyH42AKY5/JexroSXTRfX0GdlTGvwdF7yur7v7bluttPRXJHKDt2KmPCdeJtFHR; Expires=Sat, 26 Dec 2020 11:19:16 GMT; Path=/ | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | Set-Cookie: AWSALBTGCORS=FY1/3+fk1vDq0+8bRPuFIY6fZbjSd0B9tKhyWwEe8xwukw1k0YR3mWcgvg+KX0GvzFRqM5PsXMX9zItNpkvMb07ddZWcJhr5ff1RoZbylls7dQyH42AKY5/JexroSXTRfX0GdlTGvwdF7yur7v7bluttPRXJHKDt2KmPCdeJtFHR; Expires=Sat, 26 Dec 2020 11:19:16 GMT; Path=/; SameSite=None; Secure | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | upgrade: websocket | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | sec-websocket-accept: HfQ0wXPa3VV0iaYZ8pRqKZXJzWA= | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | sec-websocket-version: 13 | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | websocket-server: uWebSockets | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | Strict-Transport-Security: max-age=31536000; includeSubDomains | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Server header | | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Web socket state is now open. | 2020-12-19 11:19:07.452
BitMEX Trading Direct | Connected to server complete. | 2020-12-19 11:19:07.452
Triggering next historical data download in queue. | 2020-12-19 11:19:07.453
BitMEX Trading Direct | ~~~ debug Orders http response: ~~~ | 2020-12-19 11:19:12.792
BitMEX Trading Direct | {"error":{"message":"Your account has been disabled from using the API. Please contact support.","name":"HTTPError"}} | 2020-12-19 11:19:12.792
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:13.130 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:13.462 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:13.792 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:14.124 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:14.443 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:14.763 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:15.103 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:15.432 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:15.754 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:16.537 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:16.849 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:17.168 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:17.169 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:17.481 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:17.790 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:18.097 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:18.407 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:18.713 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.036 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.353 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.664 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:19.975 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:20.320 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:20.655 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:20.656 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:20.976 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:21.294 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:21.606 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:21.926 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:22.248 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:22.249 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:22.570 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:22.892 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:23.204 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:23.522 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:23.838 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:24.143 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:24.460 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:24.774 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:25.092 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:25.400 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:25.704 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:26.120 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:26.518 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:26.827 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:27.159 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:27.480 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:27.814 *
BitMEX Trading Direct | No 'orderID' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'symbol' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'side' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'ordType' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2020-12-19 11:19:28.131 *
BitMEX Trading Direct | Forbidden HTTP response received. | 2020-12-19 11:19:28.432
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:19:28.432
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:19:28.432
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:19:28.432
BitMEX Trading Direct socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-12-19 11:19:28.432
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:19:28.432
BitMEX Trading Direct socket (1) | Write has completed. Shutdown being performed. | 2020-12-19 11:19:28.503
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:19:28.503
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:04.014
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:04.014
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:04.116
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:04.117
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:04.117
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:04.203
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:04.203
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:04.443
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:04.443
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:04.443
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:04.443
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:04.443
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:04.463
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:04.463
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:04.463
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:04.463
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:04.463
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:04.463
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:04.533
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:04.533
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:07.473
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:07.473
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:07.473
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:07.474
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:07.474
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:07.554
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:07.554
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:07.783
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:07.783
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:07.783
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:07.783
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:07.783
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:07.803
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:07.803
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:07.803
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:07.803
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:07.803
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:07.803
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:07.872
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:07.872
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:10.807
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:10.807
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:10.808
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:10.808
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:10.808
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:10.892
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:10.892
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:11.138
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:11.138
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:11.138
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:11.138
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:11.138
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:11.151
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:11.151
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:11.151
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:11.151
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:11.151
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:11.151
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:11.223
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:11.223
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:14.161
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:14.161
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:14.161
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:14.161
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:14.161
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:14.238
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:14.238
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:14.470
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:14.470
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:14.470
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:14.470
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:14.470
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:14.473
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:14.473
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:14.473
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:14.473
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:14.473
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:14.473
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:14.535
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:14.535
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:17.485
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:17.485
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:17.485
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:17.486
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:17.486
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:17.565
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:17.565
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:17.809
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:17.809
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:17.809
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:17.809
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:17.809
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:17.812
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:17.812
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:17.812
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:17.812
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:17.812
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:17.812
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:17.878
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:17.878
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:20.827
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:20.827
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:20.827
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:20.828
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:20.828
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:20.909
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:20.909
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:21.160
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:21.160
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:21.160
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:21.160
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:21.160
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:21.170
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:21.170
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:21.170
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:21.170
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:21.170
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:21.170
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:21.243
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:21.244
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:24.178
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:24.178
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:24.179
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:24.179
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:24.179
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:24.257
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:24.257
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:24.507
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:24.507
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:24.507
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:24.507
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:24.507
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:24.527
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:24.527
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:24.527
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:24.527
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:24.527
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:24.527
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:24.676
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:24.676
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:27.531
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:27.531
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:27.531
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:27.532
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:27.532
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:27.609
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:27.609
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:27.849
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:27.849
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:27.849
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:27.849
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:27.849
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:27.859
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:27.859
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:27.859
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:27.859
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:27.859
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:27.859
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:27.933
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:27.933
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:30.873
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:30.873
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:30.873
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:30.874
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:30.874
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:30.962
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:30.962
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:31.194
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:31.194
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:31.194
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:31.194
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:31.194
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:31.204
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:31.204
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:31.204
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:31.204
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:31.204
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:31.204
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:31.275
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:31.275
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:34.212
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:34.212
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:34.213
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:34.213
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:34.213
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:34.285
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:34.285
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:34.518
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:34.518
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:34.518
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:34.518
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:34.518
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:34.528
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:34.528
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:34.528
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:34.528
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:34.528
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:34.528
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:34.597
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:34.597
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:37.535
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:37.535
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:37.535
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:37.536
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:37.536
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:37.613
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:37.613
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:37.841
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:37.841
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:37.841
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:37.841
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:37.842
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:37.852
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:37.852
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:37.852
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:37.852
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:37.852
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:37.852
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:37.921
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:37.921
BitMEX Trading Direct socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2020-12-19 11:21:39.670
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:21:39.670
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:40.853
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:40.853
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:40.853
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:40.854
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:40.854
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:40.942
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:40.942
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:41.181
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:41.181
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:41.181
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:41.181
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:41.181
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:41.217
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:41.217
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:41.217
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:41.217
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:41.217
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:41.217
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:41.286
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:41.286
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:44.224
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:44.224
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:44.224
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:44.224
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:44.224
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:44.313
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:44.313
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:44.631
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:44.631
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:44.631
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:44.631
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:44.631
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:44.644
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:44.644
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:44.644
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:44.644
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:44.644
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:44.644
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:44.710
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:44.710
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:47.655
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:47.655
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:47.655
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:47.655
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:47.655
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:47.733
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:47.733
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:47.965
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:47.965
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:47.965
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:47.965
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:47.965
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:47.975
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:47.975
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:47.975
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:47.975
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:47.975
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:47.975
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:48.045
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:48.045
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:50.978
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:50.978
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:50.978
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:50.979
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:50.979
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:51.059
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:51.059
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:51.293
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:51.293
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:51.293
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:51.293
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:51.293
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:51.313
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:51.313
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:51.313
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:51.313
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:51.313
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:51.313
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:51.383
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:51.383
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:54.321
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:54.321
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:54.322
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:54.322
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:54.322
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:54.405
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:54.405
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:54.664
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:54.664
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:54.664
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:54.664
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:54.664
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:54.684
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:54.684
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:54.684
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:54.684
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:54.684
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:54.684
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:54.761
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:54.761
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:21:57.686
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:21:57.686
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:21:57.686
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:21:57.687
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:21:57.687
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:21:57.777
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:21:57.777
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:21:58.011
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:21:58.012
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:58.012
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:21:58.012
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:58.012
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:21:58.022
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:21:58.022
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:21:58.022
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:21:58.022
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:21:58.022
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:21:58.022
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:21:58.096
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:21:58.096
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:01.024
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:01.024
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:01.024
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:22:01.025
BitMEX Trading Direct socket (2) | Connecting to IP: 54.246.177.142. | 2020-12-19 11:22:01.025
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:01.109
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:01.109
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:01.369
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:01.369
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:01.369
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:01.369
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:01.369
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:22:01.383
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:01.383
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:01.383
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:01.383
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:01.383
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:01.383
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:22:01.448
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:22:01.448
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:04.394
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:04.394
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:04.469
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:22:04.469
BitMEX Trading Direct socket (2) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:04.469
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:04.553
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:04.553
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:04.801
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:04.801
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:04.801
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:04.801
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:04.801
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:22:04.821
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:04.821
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:04.821
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:04.821
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:04.821
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:04.821
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:22:04.896
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:22:04.896
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:07.825
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:07.825
BitMEX Trading Direct socket (2) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:07.825
BitMEX Trading Direct socket (2) | New receive buffer size: 5242880 | 2020-12-19 11:22:07.826
BitMEX Trading Direct socket (2) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:07.826
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:07.912
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:07.912
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:08.152
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:08.152
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:08.152
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:08.152
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:08.152
BitMEX Trading Direct socket (2) | CloseSocket call. | 2020-12-19 11:22:08.153
BitMEX Trading Direct socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:08.153
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:08.153
BitMEX Trading Direct socket (2) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:08.153
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:08.153
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:08.153
BitMEX Trading Direct socket (2) | Socket gracefully closed by remote side. | 2020-12-19 11:22:08.221
BitMEX Trading Direct socket (2) | Closed. | 2020-12-19 11:22:08.221
BitMEX Trading Direct socket (1) | Deleting network socket now after delay. | 2020-12-19 11:22:09.671
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:11.169
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:11.169
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:11.170
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:22:11.170
BitMEX Trading Direct socket (1) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:11.170
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:11.251
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:11.251
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:11.502
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:11.502
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:11.502
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:11.502
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:11.502
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:22:11.512
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:11.512
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:11.512
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:11.512
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:11.512
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:11.512
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:22:11.586
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:22:11.586
BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-12-19 11:22:14.518
BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-12-19 11:22:14.518
BitMEX Trading Direct socket (1) | Creating socket. Using TLS 1.2. | 2020-12-19 11:22:14.518
BitMEX Trading Direct socket (1) | New receive buffer size: 5242880 | 2020-12-19 11:22:14.518
BitMEX Trading Direct socket (1) | Connecting to IP: 18.202.158.206. | 2020-12-19 11:22:14.518
BitMEX Trading Direct | Opening WebSocket. | 2020-12-19 11:22:14.598
BitMEX Trading Direct | Sending WebSocket handshake. | 2020-12-19 11:22:14.598
BitMEX Trading Direct | Server header | HTTP/1.1 403 Forbidden | 2020-12-19 11:22:14.849
BitMEX Trading Direct | Unexpected header. Handshake acknowledgment: HTTP/1.1 403 Forbidden. Disconnecting | 2020-12-19 11:22:14.849
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:14.849
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-19 11:22:14.849
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:14.849
BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-12-19 11:22:14.869
BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-19 11:22:14.869
BitMEX Trading Direct | WebSocket closed. | 2020-12-19 11:22:14.869
BitMEX Trading Direct socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-19 11:22:14.869
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:14.869
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-19 11:22:14.869
BitMEX Trading Direct socket (1) | Socket gracefully closed by remote side. | 2020-12-19 11:22:14.937
BitMEX Trading Direct socket (1) | Closed. | 2020-12-19 11:22:14.937
File >> Disconnect selected. | 2020-12-19 11:22:15.642
BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-12-19 11:22:15.642
BitMEX Trading Direct | Disconnected. | 2020-12-19 11:22:15.642
