Date/Time: Thu, 13 Feb 2025 17:12:21 +0000
sc.GetPointOfControlAndValueAreaPricesForBar for multiple bars
View Count: 549
[2020-12-19 10:58:28] |
User818063 - Posts: 16 |
Hi ACSIL provides a function named sc.GetPointOfControlAndValueAreaPricesForBar for the levels of a given bar. Is it possible to provide the same function for a period of bars (startIndex to endIndex) ? Thx. |
[2020-12-19 21:46:46] |
This is done by using the Volume by Price study and configuring it to use those particular bars: Volume By Price Study And then by using this function: sc.GetStudyProfileInformation There are some other ways to do this, but this is one way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-19 21:47:15
