Date/Time: Thu, 13 Feb 2025 17:29:58 +0000
[User Discussion] - Append Imported Historical Intraday Data to Chart with Live Feed
View Count: 529
[2020-12-19 10:48:42] |
01110010 - Posts: 33 |
I know it is possible to load/import custom intraday data files for use in sierra chart. I was wondering if it was possible to 'append' this data to the start of a live data feed. For example: The Sierra Binance Data Feed starts from 18th of December. If I obtained historical intraday data for before then, e.g. from Jan 1st to Dec 17th, would I be able to load this in and use it to add to the start of what would be the live data feed going forward. Date Time Of Last Edit: 2020-12-19 10:48:54
[2020-12-19 10:56:35] |
My bad, seem to have found the solution here: History Data import (csv)
