Date/Time: Thu, 13 Feb 2025 18:53:30 +0000
[User Discussion] - NYSE Cumulative Tick
View Count: 2635
[2020-12-18 22:48:44] |
adamset - Posts: 9 |
Evening SC team, I'm looking to open or either build this chart in Sierra. I've come across the NYSE TICK symbol, but not the "CUMULATIVE" part. Can you please assist me in creating this? Reference below. Thanks. https://www.tradingview.com/chart/qD6WYaRf/ |
[2020-12-19 01:22:13] |
QuantyQuant - Posts: 7 |
I use a study called cumulative sum of study, just set it to Last (using TICK as the price chart) and it’ll work the same.
[2020-12-19 01:35:32] |
Do you mind sending me a screenshot? I think I'm doing it incorrectly.
[2020-12-19 02:00:34] |
Sure thing, the options should look like the attached image (link in case it doesn't work: https://i.imgur.com/k6GMa87.jpg) |
![]() Attachment Deleted. |
[2020-12-19 02:10:47] |
https://imgur.com/a/oXk9Wne
[2020-12-19 02:11:56] |
Right, okay I did that but the first thing I noticed that was off was the values of the chart, and why is mine being displayed as a line chart? -- Also, appreciate your help! |
[2020-12-19 02:25:12] |
No problem, and if you go to the next tab over, called "Subgraphs", it'll let you configure all the visual settings. Just change from Line to a Bar and I do the red/green coloring by slope.
[2020-12-19 02:55:38] |
Okay great, I'm getting closer.... I am just curious at the discrepancy in values now. I do believe it's close, any ideas? https://imgur.com/a/VzFZEAX |
[2020-12-19 21:42:33] |
It looks like TradingView is just showing the NYSE TICK and not NYSE cumulative tick since it has OHLC candles. Cumulative TICK is the above, where it's adding to/subtracting from the last value through the day.
[2020-12-19 21:51:56] |
Understood, is there any way I can make what TradingView has, in Sierra?
[2020-12-19 22:39:48] |
Just use NYSE TICK as the main chart (it'll be under Market Stats in symbols), and cumulative sum of study as a lower chart study below the chart.
[2020-12-19 22:51:27] |
I followed your directions, still doesn't match. Am I doing something wrong? https://imgur.com/a/6FI4DFM |
[2020-12-22 02:18:58] |
Hmm I'm not really sure what's going on with line charts. For the TICK chart, I always use normal candlestick charts.
