Date/Time: Thu, 13 Feb 2025 17:02:38 +0000
My spread quotes no longer work
View Count: 504
[2020-12-18 16:31:44] |
User823309 - Posts: 1 |
Hi, yesterday I had quotes on NYMEX spreads using the symbol: CLG21.FUT_SPREAD.NYMEX Today those are not working. Also, now I cannot find the spreads in the find symbol window. Thanks |
[2020-12-18 18:56:45] |
This is explained here: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 242311 Set up a separate installation of Sierra Chart for those spreads: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-18 19:48:12
